Like Tree23Likes
Old 01-09-2012, 08:19 AM   #3406
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by shark2288 View Post
Are any of u guys going to switch to the gear diff when it becomes available fof the dex210?
With such a GORGEOUS, almost maintenance free ball diff, why would you want to? The last thing this car needs, is more weight in the rear-end.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-09-2012, 09:00 AM   #3407
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Cpt.America View Post
My mod from last night let me go down to 2mm on the steering block, and I am literally at 0 bumpsteer.
OK where are the pictures?
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 01-09-2012, 09:15 AM   #3408
Super Moderator
Testing first...
- RCSpecialties -
Old 01-09-2012, 09:59 AM   #3409
Trader Rating: 59 (100%+)
im sure its to flip the steering rack to the opposite side . And yes, it works.
rc23 is offline   Reply With Quote
Old 01-09-2012, 10:04 AM   #3410
onekiwi's Avatar
If its like the arrma all metal diff Im not sure but if its a light weight like the sc10 then maybe, I had a play with jörns diff att the DHI cup and it was really nice.. smoooooth with 600wt shock oil
He kicks butt with his driving.. and nearly the exact same setup where ever he goes
+ YouTube Video
Im not on the list unfortunately
No 8 is a 210 as well
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 01-09-2012, 11:19 AM   #3411
jurquhart's Avatar
Trader Rating: 22 (100%+)
I might try switching to it to see how I like it
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 01-09-2012, 01:03 PM   #3412
Trader Rating: 35 (100%+)
+ YouTube Video
anyone know if his setup is available anywhere?
nazman01 is offline   Reply With Quote
Old 01-09-2012, 01:32 PM   #3413
I agree the diff is good, but actually I put the SC10 gear diff in mine last week. I checked the weights of both and the gear diff with 2000cst was 37 grams with associated flanged bearings (no shims) and the kit diff was 43 grams with bearings, so no real big deal.
Stephen_102 is offline   Reply With Quote
Old 01-09-2012, 01:39 PM   #3414
Autocratic's Avatar
You have a part# for those bearings? I just bought my SC10 diff and my LHS didn't have any shims that were going to work.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-09-2012, 01:48 PM   #3415
http://www.ebay.co.uk/itm/10-x-15-x-...ht_1518wt_1139
See above link - any 10x15x4 (MS) Flanged Bearing will suffice. I got mine from LHS. This is a UK seller but I am sure you can find something in the States easy enough.
HTH
Old 01-09-2012, 01:52 PM   #3416
HTH
Also - you will still need to shim, just not as much. Some guys on Oople did a very good write up on it and how you need to shim it correctly to one side to let the idle gears sit on the diff okay as one side of the SC10 diff body overlaps the gears and can cause the idle gears not to sit neatly on the diff. You would need to see the diff to follow me........
Old 01-09-2012, 02:40 PM   #3417
Autocratic's Avatar
I went to my more local hobby shop and found a shim kit from HPI, #Z892, that are an exact match to the TD diff shims.
Also, did you put the two smaller o-rings on the outdrives? With them on there seems to be too much resistance.
Old 01-09-2012, 03:05 PM   #3418
Trader Rating: 520 (100%+)
Testing first...
Testing hell, we dont need no heroes here Brandon, let the cat out of the bag...
flame56mx is offline   Reply With Quote
Old 01-09-2012, 03:07 PM   #3419
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Hopefully parts will be easier to get now that Hobbico owns Team Durango.
fullsyzz is offline   Reply With Quote
Old 01-09-2012, 03:16 PM   #3420
Super Moderator
hehe... no seriously, there are some clearance issues, and I want to take a real fine look at ackerman angles before I get guys tearing apart their front ends, then yelling at me if it doesn't work right
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
