Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-23-2009, 12:18 PM   #1
Questions?? losi speed t diff problem newbi, i know nothing.
hello everybody,i am new to the rc world, i got a speed t with 3s lipo as my first car, had 6 full batery runs at medium esc setting and 15 tooth pinion gear and grass tyres, the diff was fine untill i changed the wheels back to the stock road tyres that came with it. when i tightened the wheel nuts i held the opposite wheel and then tightened the wheel nut, after reading the manual i think that i may have tightened or lossened the diff, now when the car is on a stand and i turn one wheel the other turnes in the same direction ( diff appears to be locked ) , when i use a lot of throtle the car dose doughnuts and makes a scarping/barking noise, has my inexperiance caused a simple fixable problem or has the diff eaten its self. please help. thancks very much, joney, england.....
joney is offline   Reply With Quote
Old 05-23-2009, 01:01 PM   #2
B.A. Racer's Avatar
ok ive never messed with a losi but it seems like ur diff is too tight...for the associated diff u tighten the diff till the spring compresses then turn it an 1/8th of a turn...if that doesnt work loosen it little by little... then u will have to rebuild ur diff if those adjustments dont work...try those out and let us know
Team Associated T4 13.5 brushless
Caster EX-1 PRO Tekin RX8/2050
---------DX3R---------
TEAM DRIVER FOR CASTER RACING USA/TEAM TERRIBLES/FASTLANE GRAPHIX
B.A. Racer is offline   Reply With Quote
Old 05-23-2009, 02:05 PM   #3
The speed-T has a locked diff. I am 99.9% sure. It is designed that way so it is easier to drive at high speed.
cstroh is offline   Reply With Quote
Old 05-23-2009, 04:41 PM   #4
88NATE's Avatar
i don't know if it's lock diff but i know that you can get one for it, if you mean it makes scraping/breaking you and i know it's not supost to do that so why don't you take it apart, it's not that hard just go slow some times the bet answers are the simple ones
88NATE is offline   Reply With Quote
Old 05-23-2009, 04:57 PM   #5
the speed t comes with a locked diff that i know because i own one
bbs racing is offline   Reply With Quote
Old 05-24-2009, 02:57 AM   #6
Thumbs up speed t
thancks for the info, when i got the speed t the diff worked normal ( turn the right wheel forward and the left would turn backwards i think ) i will take it back to the shop for some education befour i try to pull it to bits, i will post the result of my schoolin, i allso noticed that i have got a slight bend in the left dog bone at the wheel ..oops.. thancks again, joney...
Old 05-24-2009, 04:51 AM   #7
Smile i am thick
hello again, the diff is fine, you are right the diff should be locked and the bent dogbone is within tolerance, i am never to old to learn new things, see you all next time when my lack of knowlage lets me down. thanks again to everybody. joney...
Tags
diff , problem , speed t
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
