Spur gear issues
Old 05-23-2009, 07:35 PM
Default Spur gear issues
My XXX-4 has had the issue of repeatedly breaking spur gears. It's happened three times now.
All that happens is a single tooth snaps off.
What can i do to prevent the same again?
Thanks for help
zaner123 is offline
Old 05-23-2009, 07:47 PM
Thanks for help
Sounds to me like your slipper clutch is too tight. I would loosen it up.
pede_187 is offline
Other than making sure your gear meshing is good, not much. Maybe try another manufacturers Spur, if they are compatible?
Good luck!
CODMAN
CODMAN is offline
Old 05-23-2009, 10:54 PM
xBRxSAIGON's Avatar
[QUOTE=zaner123;5849746]My XXX-4 has had the issue of repeatedly breaking spur gears. It's happened three times now.
What motor are you runnin'?? I run an 8.5 Novak w/ a 92t Kevlar and have no issues, W/ proper gear mesh that is..
xBRxSAIGON is offline
Old 05-24-2009, 06:11 AM
sLaSh It UPP's Avatar
Thanks for help
the only thing you can do is learn how to mesh you pinion and spur gear better
sLaSh It UPP is offline
