Is my ESC toast?
Is my ESC toast?
I've been sick as a dog and bored, so I decided to swap out my esc wiring with Wet Noodles.
My soldering iron is only a baby, and it took a while to get all of the old build-up off a few of the posts. I didn't heat them for too long at a time, but it took ages to get most of the gunk off.
Anyway, by the time I got the new wires on, hoked it up, and ran it on a stand, I started getting smoke. Damn. Only a bit so I stopped, gave it 5 minutes and got PO'd, so started it up again. The smaller heat sink was scorching, so I unhooked it agian.
Now, by this stage I was getting grumpy as I spent a good deal of time tidying it up, so I let it cool down and then hooked it up and took it outside.
It didn't get hot, but has no brakes.
Any ideas?
I'm in NZ, and guessing it's too much cost and trouble to get it sent 1/2 way across the world for repair!
Any ideas?
I'd make sure there's no stray solder connecting two solder points...but if you already got smoke, something in the ESC definitely poofed. When it comes to electronics, smoke means something died a fiery death - there's no "almost" dead. If you accidentally created a short with some stray solder, that'd do it.
Yeah, thanks for that guys. I figured it was dead.
I opened it up, and the solder on the PCB looked as though it had heated up and spread out a bit. I'm guessing it's now to be binned.
It was the small heat sink that was scorching, and i'm guessing that the large sink is for forward, and the small one for reverse. May be completely wrong, but it's irrelavent now!
Thanks for the offer, sounds like a good deal, but I think i'll use this as an excuse to go brushless
Sounds like you burned out the brake fets. If the speedo is Novak, you can return it and exchange for a factory refurbished with a new warranty or you can upgrade to a newer better ESC. Fee is very reasonable.
yeah heat sink got hot, you smoked the reversing mosfet. keep it and have no brakes/reverse or send it in for repair/refurb.
Thanks for that nutz, i'll look into it.
If all else fails, I guess I could just use it as forward only. No brakes, that's how real men ride
