Tekin Redline RS Sensored ESC and motors, opinions for offroad?
#3031
Randy, I got my RS Pro back this week from being repaired, set it up and worked fine. Decided to make some changes to program with the Hotwire. Applied the setting, reset the transmitter endpoints and now it flashes the first two and last two. I know it's not in the wrong mode. Let it sit while at the track for about 2hr tried it and it worked fine. Turned it off then back on and ever since it flashes first two and last two again. Any idea what is going on? The other 2 units I have work flawlessly. This one though is driving me nuts. Thanks
#3032
Nope, BL-FW. Brushless forward and brake only. I never run with reverse. As I started racing in '85 a good esc for racing didn't have reverse. And ROAR rules does not allow reverse. Thats one thing that our local track fails to enforce. That and since when did "Novice" class allow anything but stock motors (17.5 these days).
#3033
#3034
If you just received it back and it didn't work it's under warranty. Please contact [email protected] or hit me up on Livechat today.
#3035
Ok, just curious. My RS pro showed LED's 12&67 flashing for no reason one day. It worked fine one minute and then it just flashed. I thought it was done and it set on the bench waiting to be sent back in. I hooked it up to receiver only the other day to test receiver on my car and it functioned normal. I then connected it to the motor and it started flashing 12&67 again. I checked it with hotwire and it was set on brushed. I have never changed this setting from brushless yet some how that is where it was set.
#3036
It's unfortunate you don't have your copy but we do track them in the system. If you write a detailed note and try to give us an idea when it was in for service we can try to track it all down. We're here to help, not hinder.
#3037
#3038
#3041
Is 222 or 223 available for download?
#3042
It will be shortly. Likely sometime after the weekend.
#3043
Having same problems as others here.
Just got my speedo back from service. 12 67 are flashing...
On the invoice they said NPF.
Tried a factory reset, hooked up to car...nothing. When connected to hotwire 12 67 flash. This happened ever since my 222 update.....i put all my other RS Pros back to 212.
#3044
222 didn't cause this issue. 12 67 fault can be the Motor type setting so make sure you're on MT 1 2 or 3.
