new battery voltage not good?
ive cycled my new gp3300 5 times and they only get a peak charge of 9.05v at the best. will they get better over time and more cycles on them?
i charge at 5.0 amps and was thinking that was the problem so i tryed 6.0 amps and still the same results, any help would be great.
xxxtracer32;
Actually, that is a normal ending voltage for GP3300's. These batteries have a lower peak voltage than say 2400 Sanyos, but the performace is better.
Usually the Higher ending Voltage, the less performance (High I.R.) you will get from the pack.
i put the pack in and ran it in pratice and it was realy punchy and fast so im happy with knowing that the 9.0 volts is normal thanks for the reply
