Help Please Head bolts stripped
If the screw heads are stripped you can take a dremel and cutoff wheel and grind off the screw heads. Then pull head off and studs out.
Mr Tony Montana, was gonna give u a call today but it got too late on me. trying to let u know that I wont me able to buy the K2 like I said I would. I got a good deal on an engine and could not pass it up. So the money went to the new powerplant. Just wanted to let u know in case u get any offers for it. Sorry to back out but I am done spending big money for this season after buying this new engine.
Me and John still going up to pasadena this weekend. See u up there.
Thanks for understanding.
I went up to Waldorf and they had a VZ-B seating pretty on the shelf. Jimmy gave me a good price on it so I jumped. Already started doing the break in and it is running pretty sweet. Gonna keep it as a back up for the State Champ weekend. You going up to Pasadena this sunday?
What's up guys?? I was going to make the same post Slobbatech did after I read your post. He beat me to it. I see you got them out, that's cool. Did you get a different head for the 01B???
I can't make it down to Pasadena this weekend. I'm getting 2 teeth pulled Friday morning and don't think I'll be up to racing much over the weekend. We'll see though, you never know. If the pain is any less then it is now, I might make it. On the other hand, I might cruise down to Homers and practice for the nat's. if I feel better.
Also, Javier, how are/did you break in the new VZ-B?? Did you follow Steven Bess's break-in procedure? Whatever you do, don't run it on the box other then to get the heat in it. You don't want to run it rich, make sure the temp comes up as to heat cycle it for a tank. Then throw it on the track, run it alittle rich for a few tanks then lean it for performance. It's good to keep an eye on temps but only for reference.
Greg, I used the heat cycle method(Bess). Weather is kinda meesed up so I dont want to do much needle teaking till I run the engine on the track. If I make it up to pasadena this sunday I will probably try to do some more break-in/tuning after the racing is done if i have the time. Wanna run the V01B that day since it will be the engine I'll use for the MD Champ race. Want to make sure it's tuned correct for the track. Also, are u still running the sliding clutch(Fioroni)? Which set up u liked better on the OS ie 2,4,6 point, black or white shoes?
I only have a 4 point right now. I'm ordering the 2 point to try out with the Sirio. The 4 point on the Sirio was OK but it lacked the bottom end I want. I liked it but it needs a 2 point. I think the OS worked great with the 4 point. However, the Sirio needs the 2 point. . It should give it more bottom end punch. You know, come in later.
Greg, did u use the carbon four point? Gonna give it a try. I can get the shoes locally but need to find the flywheel for it.
Tony Montana
U going up to pasadena or are u gonna keep running away scared
