question about esc
question about esc
what is the difference in esc and the other other speed control that comes on a stock traxxas rustler i can get a new traxxas rustler without esc and i could buy esc and esc mount for cheaper than i would be paying for a brand new traxxas rustler with esc already installed
also is it hard to hook esc up
The mechanical speed controller in the rustler has a servo, which rotates an arm, which changes how much power goes to the motor... and how much power is burnt off via a resistor.
An electronic speed controller turns the power to the motor on and off - at different rates, to achieve the desired speed. No servo, no resistor.
ESC is more efficient. You'll get more run time and better performance.
You dont need the ESC mount for the rustler. A bit of double sided tape onto the chassis works fine. Actually - i think its better than using the ESC mount, as the ESC will balance the weight of the receiver.
ESC easier to plug up than an MSC. ESC plugs into the receiver, connects to the motor and battery - and away you go!
so msc will work for a couple weeks until i save up the money for esc also will a 6v battery work in the rustler
Um... it will "work" on 6v - but it will be awfully slow!!
ok thanks alot for the help
