RC10T6.4
#196
This is it for the most part. I don’t have the B74 hubs and have 2mm pistons. I also had 30k diff fluid, diff was low on fluid and refilled with 50k just to try it. I tried ride heights from 15mm to 19mm and could not stop the “diffing out” problem. I didn’t have any traction roll issues yesterday but it still felt like I couldn’t push it hard. Suspension needs a little work because of the harsh landing after a big table top if not landed perfectly. Just looking for minor tweaks to try.
#197
also, I believe that sheet has an error, rear hub height should be hole high/axle low. The setup sheet reads backwards.. the pictured insert doesn’t match the description
#198
I am running swagger fronts and pin down rears
#199
have you tried closed cell foams in the fronts? I started running them last year and noticed it allowed me to lean on the truck in the turns much harder. The foams don’t collapse like open cell, the truck stays predicable in hairpins or sweepers, the bite feels the same.
#200
#201
#202
But in all reality i'm sure I'll be shaking like a leaf battling for 5th in the F main, lol
I'd be happy just to make a C main. I'm sure i'll fit in with some other racers, just not sure where. Looking forward to it.
#203
I'm way faster when I don't give a care.
A half second a lap easy, offroad. And I never care onroad.
#204
Are there any options for more durable front arms? The track I race on has large jumps and is very abrasive, the front arms take a beating,
I've just had both sides of my first set break at the hinge pin in the last week. I've ordered an RPM P/N 81352 skid plate to try and give the area a little more protection.
#205
same tires as that sheet? I’m a bit confused about his sheet, specifically the rear camber link (roll center) adjustments. Have you tried the one I posted? Even with stock pistons it was definitely in the track, tons of grip and tons of steering.
#206
Youre right, I read it backwards. When the T6.4 sheets were first released, the diagram and the description didnt match.
I have attached my setup sheet to this, looks like Jovy and I run very similar setups aside from some roll center and total caster adjustments which are probably the effect of different traction levels. My truck is on rails and turns very smooth. Putting the HT +1 steering plates on really mellowed out the harsh initial turn in the truck had out of the box. For dirt, you most likely need that harsh initial dive in, but with the bite of carpet I felt it needed to be tamed, also why I run closed cell foams up front to keep the tire from rolling over on that initial turn in.
#207
One thing that i just realized after looking at both setups, Jovy and Cinnabun, I still have a rear anti roll bar attached. I wonder if this could have caused the truck not to roll enough in the corners??
I also want to double check my bellcrank position, i am running the same bulkhead, caster blocks and inserts as you Cinnabun. So total caster at the wheel should be 27.5.
I also just ordered some 2.5,, blank pistons, the +2 rear ballstud mount and the Avid -2 C block.
This will give me the chance to go through and double check the whole truck and run it atleast one weekend before we head out of town.
Thanks for all the help guys, much appreciated. I love this T6.4 section along with the B6.4 group as well, lots of knowledge and good people!
#208
Im also playing around with lowering the inner ballstud on the front camber link to add a bit of push on corner exit. Its much easier to me, to drive a car with a small amount of push. Again, I dont want to recommend these 2 changes above to someone looking for a solid setup just yet. I havent spent enough time with the truck on the track to get it dialed in just yet.
#210
My understanding is you use the complete buggy front shocks with a buggy front tower and the stiffest buggy spring sold. Then you need to bend a 1.4mm bar and source the necessary pieces to mount it to the top of the front top plate. I think Spencer is using some mounts from the TC7 to secure it but you still need the rest of the hardware to secure it to the arms. Or you can try the thicker front bars sold by Revolution Design. Their largest bar might bind in the front ballstud mount and if it does it will obviously affect performance.
The rear shocks are a mixture of truck bodies and buggy rear shafts but they use the truck rear springs, and the buggy rear tower. From the pictures I have seen they are also running a rear bar but I don’t know the size.
I purchased my towers from Factory Foote.
https://factoryfoote.com/
I haven’t run my truck on dirt yet but hopefully later this week I can.
Have you ran your truck with the buggy towers and shock setup yet? I am looking at installing those towers and shock setup on my truck but with a carpet setup very soon and wondered what your thoughts were.
Thanks.
