Team Yokomo YZ2 CAL3.1 / DTM3.1 / SO 1.0
#286
#287
#288
he also make some "shims" that go into the guide for different cut sizes. I'd say specify what foams you are wanting to cut so you get it the way you want, but he was very helpful in the past. His name on Rctech is Cromulent .
#289
So as part of a modified class here that has a tire limit rule (no carpet tires, clay style, etc are allowed), I am going to give some honeycombs a go on rear (fronts can be anything). been awhile since I last ran those, and we are allowed to sauce them, any tips you all have when running them on grey CRC carpet?
#290
As an update, tomorrow is the big day so for the next leg in the RC Underground Winter Series in Warren MN, 1 more after this, got a new setup to try here with the AE 13mm shocks, will report back on how it goes, main thing is going with bigger piston holes for closer pack / dampening measured settings to what I was using with Yokomo shocks, based on Ray Munday's charts:
#291
Got a race report here:
RC Underground Winter Series Round # 5
Fast track layout this time:
For 2wd Buggy 17.5 Spec class, the Tekin power curve profiles and other setup options gave consistent power delivery as well as breaking action to prevent getting out of sorts going into a high speed 90 degree turn with 2 jumps in it. Finally got a setup going on the new 13mm shock package on my Yokomo CAL3.1, basically beyond a SO 1.0 at this point and was able to TQ the class in the first Heat, while unfortunately breaking out in the second. Going into the main the track conditions became almost greasy, but I was able to take the win with apparently a lap on the field due to the consistently of how the car delivered power to the surface, setting what appeared to be the fastest lap of the night, beating my TQ's best lap by .01 second.
I have been playing around with the AE 13mm shocks, and I would say after the changes I made the car was extremely consistent and handled the more aggressive jumps and landings better than my 12mm shock setup. I hope Yokomo gives this a look to make there own version with their quality.
#292
Can anyone recommend a good bungie/rubber band battery strap upgrade? Thanks.
#293
https://factoryfoote.com/product/fac...ttery-holdown/
#294
Can someone tell me if the battery holdown for the cal3.1 also fit the cal3? Thanks
#296
Thanks. New to Yokomo so I'm trying to figure out what parts interchange between the 3.0 and 3.1.
#297
#298
