5Likes
Green slime
Green slime
Is it used to stop o ring swelling? How often does it need to be done?
It's used for asssembly and for smoother action. Stops the o-ring from tearing when first building shocks with a dry shaft, although you can use shock oil for that
Never seen an o-ring swell
AE and TLR both deal with the swelling differently, AE suggest you cover the O rings in slime (I use grease) to stop them swelling - after a couple of years they bind and need replacing. TLR on the other hand duggedt you soak the O rings in shock oil over night to get them to swell, they are known to leak for a few days then once fully swollen they are fine.
And prepping a tini or ticn shaft?? Hmm with a brass brush.
Personally, I’ve done both on my 1/10th TLR buggies - soaking in the shock oil, and in my case applying 110% Racing’s RC Sweat to the rings before installation. I haven’t had leaking issues with either method.
I recommend slickoleum. You get a lot more for your money and it works great.
