Beadlocks with Small Tires
I put some tiny 1/16 Summit tires on a set of 2.2" beadlocks I picked up. It's nice not having to mess with glue!
Hey St.G, nice looking rig. Is that a TRX chassis under the body? If so, what is the body? I've got a Rustler that could use a street savy body. It's cool. Agree gluing tires can be a bit of a pain at times. Tried a set of bead locks once and they were o.k. for low speed applications. Cheers. 'AC'
I'll check out that body. May be its too wide for a ST since its on a SC chassis. Looks good on yours, though. Have a '41 Willys body I've wanted to mount to something for a long time. Like yours better. Puts me in mind of a '38 Ford-which was a favorite of mine back in the '60s. Cheers and good luck. 'AC'
Back on subject. Betting those smaller D tires really slams the chassis to the ground. Corner better does it, St. Geo?
What pinion/spur gearing did you end up with to compensate for the smaller diameter tires? Were you able to gear high enough to make up the speed loss from the larger diameter OEM tire set? You said you're getting good speed out of the conversion.
Cheers. 'AC'
Cheers. 'AC'
Cheers. 'AC'
Cheers. 'AC'
