Stampede 2wd Extended Chassis
There are lots of nice 313mm wheelbase truck bodies out there so I decided to stretch my 2wd Stampede a little to accommodate one. I made the chassis out of 1/4" thick aluminum flat bar. I think 1/8" thick would have done the trick but I was a little worried about flexing and bending. I can post pics after I get a body if anyone's interested.
What body do you plan on putting on it?
I really like the TRX-4 Sport pickup body. I'm also thinking of the '73 Bronco body from Proline.
Sorry for the late response. Right now I'm only using a brushed 27 turn motor so it's very weak and not at all prone to wheelies. I'm planning to add a brushless motor in the 3000 to 3500 KV range soon and I'll let you know how it behaves then. I think the extra chassis length will really help reduce the wheelies and I've heard that that is the case from others.
I went with a TRX-4 Sport shell.
You mean the Slash? The 2wd Slash wheelbase is around 335mm I think. My truck here has a wheelbase of about 315mm.
