Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Is that the type of answer a Hitec engineer would give to a manufacturer of optional wheels? Ask someone else. Your more then happy to write in your instruction sheets what servo horns fit your servos. It would be kinda funny to write in them to go ask the horn manufacturers if they would fit, wouldnt it. This forum is called Ask Hitec.
I would have though you would know more about your radios wheel mount a bit more than that. Thanks for trying,... I guess.
Maybe some other forum surfer can help me out here. I know I am not the only one that wants to know.
Does anyone else know if the wheel mounting of a Hitec radio (Lynx 3D) is the same as: Futaba, Airtronics, JR, Traxxas, or other?
On the Lynx 3D, the wheel mounts on a protruding piece of round plastic rod with a flat cutout on the bottom. Are any other manufacturers similar?
The simple answer is that you are asking Hitec about other manufacturers equipment. We don't make an aftermarket wheel and cannot comment about another manufacturers product. If they don't list that it fits a Hitec radio then chances are it does not. To confirm if there is a chance it will, you need to ask the manufacturer of the product. i.e. in this case it is the manufacturer of the aftermarket wheels.
