Leisure Hours Raceway Joliet IL
#20
I'll be there for 1/8.
#21
Originally Posted by JonnySocko
Anybody running this weekend? I want to come up and check out the onroad but I don't want to be the only one there.
Walt? Ira? Dune? Howard? Nexus?
Socko
Socko
#22
I might have to get my buggy dirty too! I have never had it on a track.
#23
#24
Which buggy? I may have some parts left over (had lots of OFNA buggies).
#25
What I can really use is the normal suspension parts that tend to break, plus any shock rebuild kits you might have. I think that the pistons in my shocks simply have too large of holes in them. Even with 90 weight oil in my shocks, the things do very little damping. Either the kit didn't come with other pistons (with smaller holes), or I lost them somewhere along the way.
#26
shocks
Ron- Will Mugen XR shocks work for Walt? I have several sets laying around from times past...
Walt- If you want to jump up in performance a couple of years, I have a Mugen XR Works roller and spares ready to go. This things a tank, and the reason I hve tons of spares is because it never broke.
#27
Walt, I have a worlds 2 carcass laying around. Will bring it along. Kyosho pistons fit your shocks, IFW115- 1.4mm 2 hole is the way to go. I have those in stock too. Instead of buying new pistons, you can glue a toothpick into one of the holes on your pistons (cut off the excess of course). Blocking off one of the holes puts the stock pistons in the 'ballpark'. Kyosho pistons are machined & more accurate. I'll bring some along incase you want them.
Don't remember having a problem with the dual-disc set-up. Perhaps I made some mods I don't remember. Been a long time since I ran that buggy. One disc is adequate in the rear anyway.
#29
Originally Posted by Walt
I was just going to ask this very question. I am planning on being there this Sunday. I'm going to try running both 1/8th on-road AND 1/8th off-road. Should be interesting.
Walt and Ron...let me know about the tire wear on 1/8th, is 37 (instead of 35s) are the way to go...? I can't afford a set of tires for just practice.
Jonny....next time when i am there, I will probably run MOD Electric with foams....just got a Losi that can handle almost any surface.
