ROAD RAGE Hobby Speedway, Green Bay
#751
Holy man! Wheelies you say? Wow have'nt been on in awhile, to lazy i guess.
Scrad, Don should have some extra bodies there if you would like to try one. I think Dan will be running one. Sorry no paint jobs, I ain'tz gotz the time or the energy. I'm burnt out.
Is mr staniak runnin 12th also?
Still no MI2, this blows. Should have my hands on a PRO4 tomorrow if anyone is interested.
See yall Saturday.
See yall Saturday.
#753
brian, thanx, i'll take that, i might want to go back to trackside during spring break. But do you have a RR setup?? lol, just tell whats different in setup between RR and scottys. thanx lutz, i'm putting all my stuff together for this one race. new motor, trued tires(first time trueing this far down). Lots of new chassis parts, including a new chassis, lol, busted one last week.
#754
Jason If you read this before you leave. I did alot of searching and all bodies that are the style as don's have the wing mounted just even with the wheel wells but mounted way back even or just a bit past the back.
#755
Here are some pics of Dons Body. Anyone want to give some feedback feel free. It is a prototype and some changes are already in the works.
#756
front
#757
pro3- Here is my Losi set-up I ran at Road Rage
Front- 1 toe out, 4.5 ride height, 1.5 camber, 6 degree caster blocks,2mm droop over ride, .070 swaybar, 2R pivot support, middle arm spacing, foward ackerman, 40wt, 57 piston, orange spring, #3 shock, #2 camber, Losi low roll center, Associated wheel hex
Rear- 2 toe, 4.5 ride height, 1 camber, 0R pivot, 2mm droop over ride, .090 front & .030 rear spacing, tit. ballstud in b hole offset hub, ouside lower shock mount, 40wt. 56 piston, white spring, #3 shock, #5 camber, .5mm spacer for wheel, Losi low roll center
Losi Alpha body
Losi Alpha body
#759
thanx brian, gotta a few questions. First, i run stratus bodies, i'm going to try another racers alpha body next week at my lhs track, see how i like it, right now i like the 2.0, but if there is a huge difference, i'll be giving jason another call, hehe. Also, in the rear, i run the losi low, but grind some more off them to get them lower, i'm trying that next week too. Would it be okay to run the assoc. hexs in the rear, i don't have any spacers that fit nice, and i got plenty of hexs. Also, lol, how do you check droop, i don't use the screws(bent bumpers), so how do you check it now, before i just left it be. other than that, my set up is the same, purple plaids, how far do you true them down? I got about 2, 1/8 inch right now(no metric ruler handy). Last thing, i have the old style chassis(keep breaking them, but there cheaper than the new ones), so i can't change the ack. How is your driving style, very laid back smooth, or aggresive, on the edge of crashing, lol.
#763
thats what i thought, lol, good, like having lots of steering, RR, i might tune down my D/R though, grinding issues.Otto, whats you first name, i keep frogeting.
#765
yeah, thats what i thought, i'm like i remember racing against nick and brian, yeah ,thats right.
