First pratice, setup help needed
I came back from trackside today and i found out that i need some setup help.
I own a tc3 with a novak 17.5 brushless motor, ds8417 servo, stock spur and a 36 tooth sprur gear. for shocks would be hpi yellow in the rear and hpi white in the front. I dont remember the shock oil i am running. I am not sure of the camber or toe in.
Do you have any sugestions of what i can do or what can be changed to improve my car?
When I raced a TC3, along time ago, I always ran blue TC3 springs in front and either blue or silver TC3 springs in the rear with 50wt front, 40 weight rear. 1.5 camber front and rear. 0 toe in front with 1-2 degree toe in rear.
How do i check if my diffs are too tight or too loose.
If anything, i am looking for more of a starting point.
I found this site that goes into detail about the theory of tuning. http://users.telenet.be/elvo/
ae has a great tc3 setup guide on their web site, its like $5 and it explains everything very well.
http://www.teamassociated.com/newprod/tuning_guides.htm
After you build the diff, put an allen wrench in each out drive and hold them tight, then try turning the gear. If it moves (slips) hard but moves, you are set. If it moves fairly easy, tighten it slightly and try again. If you cant move it, its too tight. I think Associated calls for one turn out from seated.
Team Associated has lots of info at their website specifically about the TC3. Start here...your diff question is answered here too:
http://www.teamassociated.com/racerh...set.htm#Setups
You absolutely need to know camber, toe-in/out, and shock oil to know how to improve the car. Droop and tweak are very critical as well, and should be checked constantly. Fine adjustments can make a big difference on carpet.
A free drivetrain is important in the TC3. Make sure that the diff cases are not torqued down, as that can easily bind the drivetrain. I remember that guys used a dremel a lot to free up the bind as well.
On-road is all about being smooth and holding corner speed. That being said, the TC3 is still a great car after all these years. Racers at trackside know how to tune the chassis, all you need to do is ask.
