Like Tree2Likes
  • 1 Post By ammdrew
  • 1 Post By ammdrew
2019 MMR Challenge
Old 01-08-2019, 05:04 AM
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Default 2019 MMR Challenge
Dates are set. Mark Your Calendar! Feb 22nd - 24th..
You can expect a early pit move possible Thur evening the 21st between 6:30 - 8:00
Practice Friday 22nd 10 - 10
3 Qualifiers Saturday 23rd
1 Qualifier and Mains Sunday 24th
This is The Big Show coming to Minnesota and we have been proud to do that for over 13 years. Wow 2019 is going to be great we have come so far and are super proud of all the diamonds that have developed under pressure out of MMR's House.
Race flier will post shortly. Entries will open on RC Signup around the 1st of the year.
Past Challenges:
MMR Challenge 2018 FEB 23-25
2017 MMR Challenge
MMR Challenge, Jan 1-3 2016 Over a Decade Of Champions
2015 MMR Electric Challenge, Where Champions Are Crowned
2014 MMR Challenge
http://www.rctech.net/forum/events-r...ge-2013-a.html
http://www.rctech.net/forum/events-r...h-jan-1st.html
http://www.rctech.net/forum/minnesot...-8-9-10-a.html
http://www.rctech.net/forum/minnesot...10th-11th.html
http://www.rctech.net/forum/minnesot...4-25-26-a.html
http://www.rctech.net/forum/minnesot...19th-20th.html
http://www.rctech.net/forum/minnesot...allenge-2.html
Entries are Open
https://www.rcsignup.com/events/disp...nt.cfm?ID=6807
ammdrew is offline
Old 01-08-2019, 05:07 AM
ammdrew's Avatar
Euro Truck Rules for 2019 MMR Challenge
  1. Legal kits: Item 58632 RC Team Hahn Racing MAN TGS (TT-01 type E chassis) & Item 58642 RC Team Reinert Racing MAN TGS (TT-01 type E chassis) MARCH 1st 2019 58661 Buggyra Racing Fox will be allowed
  2. The kit must be built EXACTLY per the instruction manual.
  3. The ONLY Hop-Op Option permitted is Ball Bearings. (ANY BRAND of bearing)
  4. Must use stock pinion and spur gear.
  5. The kit Tamiya TBLE-02S ESC and kit supplied motor (item 54358 RS-540 Torque-Tuned Motor) must be used. Battery connector may be changed to DEANS type. Motor Bullet connectors may not be removed. NOTE: ESC & Motor wires may not be shortened!
  6. All body parts must be used.
  7. All screws in the kit must be used. I.E. You may not omit screws to change the handling of the truck.
  8. Minimum Weight: 1450 grams. Adding heavy ballast for low CG is prohibited.
  9. Adding FOAM material to the kit foam bumper is permitted.
  10. Must use kit tires and wheels. Kit tires may be glued onto wheel.
  11. Any grease or lube may be used to lubricate gears or moving parts.
  12. Batteries: Any stick-pack style, hard round case type LiPO, NiCD, Ni-MH is permitted. Examples: Reedy Wolf-Pack or Peak Racing Powermax batteries are good for this class.
ammdrew is offline
Old 02-05-2019, 08:58 AM
ammdrew's Avatar
Trophies and Tire orders about to finalize. Make sure you get signed up we are less then 3 weeks out. https://www.rcsignup.com/events/displayEvent.cfm?ID=6807
ammdrew is offline
Old 02-11-2019, 10:56 AM
ammdrew's Avatar
qcrc likes this.
ammdrew is offline
Old 02-19-2019, 05:59 PM
ammdrew's Avatar
Just 3 days from move in.
ammdrew is offline
Old 02-20-2019, 03:33 PM
ammdrew's Avatar
Just a day away from move in
ammdrew is offline
Old 02-20-2019, 03:35 PM
ammdrew's Avatar
Going to be a hot weekend on the track!
qcrc likes this.
ammdrew is offline
Old 02-21-2019, 07:36 AM
ammdrew's Avatar
ammdrew is offline
Old 02-22-2019, 04:57 AM
ammdrew's Avatar
ammdrew is offline
Old 02-25-2019, 05:24 AM
ammdrew's Avatar
Some Euro Truck A amain action from the weekend.
ammdrew is offline
Old 02-25-2019, 04:16 PM
ammdrew's Avatar
ammdrew is offline
HTML code is On
