will this pc work?
Old 04-16-2013, 07:36 AM
  #16
wfdfiremedic's Avatar
Originally Posted by Andy w
I ended up buying the setup I listed but used a samsung ssd. I also bought the video card as I couldn't pass up the deal. It ended costing me $920 total and it obviously has no problem running VRC on any setting I put it on.
As far as VRC, it is better than I expected. I feel it will keep me in shape on the weeks that I can't make it out to the track but probably won't make me a factory driver also. I didn't have massive expectations but it is more than a game, it is a sim.
The only thing that it is off on to me is the lack of "feel" when a car brakes loose on a sweeper or the feel of the spool exiting the corner. I don't know how we can "feel" the car reacting in real rc racing but you can and there is a lack of feel on VRC, at least to me. But so far I hve 15-20 hours on it and have enjoyed it a lot.
Hi,
One of the things that is also very important in vrc is the monitor. I don't know if you are using a good computer monitor, but a lot of tvs people use as monitors don't cut it. The response and lag time for this game is very important. I was playing on a tv for a bit, but the feel of the game was horrible. The lag times were too high making the tracks feel like there was a lack of traction.
wfdfiremedic is offline
Old 04-19-2013, 06:50 PM
  #17
Andy w's Avatar
Originally Posted by wfdfiremedic
Hi,
I am using a 46" LCD TV. Have had no problems or lag that I can tell,
Andy w is offline
Old 04-21-2013, 08:35 PM
  #18
stunter38's Avatar
Trader Rating: 73 (100%+)
like to know if this will work?
CPU: Intel E8400 (over-clocked to 4.0 GHz, Prime95 stable)
RAM: Corsair Twin 2x4096-6400C4DHX
Video: EVGA GTX 460 SE, 01G-P3-1366-TR
Motherboard: EVGA 750i SLI FTW, 123-YW-E175-A1
Power Supply: Corsair GS600
Hard Disk: 2 x 500 GB 7200 RPM (1 Seagate, 1 Hitachi)
Optical: DVD writer
Case: Cooler Master CM Stacker 830 (black)
Case Cooling: top-mounted 120mm intake, bottom-mounted 120mm intake, rear 120mm exhaust
CPU Cooling: Thermalright TRUE Black w/ 120mm PWM fan
OS: Vista 32-bit SP 2 installed and activated (Windows 7 available for additional cost)
Other software installed: Microsoft Security Essentials, Adobe Flash
Also included: original case box/packing
stunter38 is offline
Old 04-22-2013, 05:29 PM
  #19
stunter38's Avatar
Help me out here
Old 04-23-2013, 02:01 AM
  #20
Saw this thread so i thought i'd download and try - I'm running the following and it works fine for me:
CPU: E6600
Ram: 4gb (no idea what it is)
Video: Sapphire Radeon 4850
Motherboard: Gigabyte M3A78-EM
Powersupply: 500w
Operating system: Windows 7 32 bit
basic case, couple of 1tb hard drives etc.
Runs smooth, no complaints - your gear looks more advanced than mine but you might want to do a bit of research to be sure.
Can't you download the free trial and just check?
pannas is offline
Old 04-23-2013, 09:49 AM
  #21
Optical: DVD writer
Your setup is kindof old. You might not be able to run with full blast but you might be able to get a decent framerate. Best bet would be to do the free trial.
mccoyer001 is offline
