-   VRC Pro The New R/C Racing Simulator & Community! (https://www.rctech.net/forum/vrc-pro-%96-new-r-c-racing-simulator-community-163/)
-   -   SC Motors? (https://www.rctech.net/forum/vrc-pro-%96-new-r-c-racing-simulator-community/653669-sc-motors.html)
rcgerber 08-12-2012 09:04 PM
SC Motors?
OK did I miss something. How is it that people are able to change motors in the new off-road. My only option is the spec 17.5 with no options that I can find to change it. Yet I'm running against folks with the 13.5, 8.5 and 7.5 motors, which I paid for but don't seem to have access to. What am I missing.
T. Herwig 08-12-2012 09:46 PM
Make sure you change your Chassis type from the "stock" one.
rcgerber 08-13-2012 07:38 AM
Thanks, but I don't seem to have that option because I've looked. I'll check again when I get home from work, just to make sure.
RandyA 08-13-2012 02:05 PM
basically you'll need to build a new car from scratch. from the main screen click on "car-setup" in the top right corner. then from the tabs listed on the left side of the screen, the top tab should be "chassis", click on chassis to select a new chassis. keep in mind that both the a mod chassis and a mod motor will need to be purchased. ..then continue building your car with your desired components.
rcgerber 08-14-2012 07:28 AM
I've been using VRC-Pro for about 4 months so I understood the new chassis build. I just didn't have the non-stock chassis option till last night :D . So I'm good to go now Thanks.
