RC10T VS RC10T2 compatibility?
iv got an RC10T that needs a lot of parts. so far i seem to be able to find what i need directly from Team Associated's website.
question is, are the steering cranks between the RC10T and RC10T2 interchangeable? or could they be interchangeable by swapping a few parts? |
Im not sure about the T2 steering parts, but the bellcranks from the rc10 buggy work just fine. I used the ones from a rc10 worlds car rerelease and the shorter bellcrank made the truck drive better.
it didn't make the truck twitchy? being shorter i would think that it would make the steering quicker. if it still drove good ill give them a shot. looks like i can get them directly from AE.
I've got GT1 bellcranks on my T.
It made a nice difference, it felt more consistent and easier to drive. Not sure if its cause of less flex or the geometry or what, but Im glad I did it.
Plus getting rid of the trucks built in servo saver tightened things up too. Todays servos just don't need as much protections as the period servos did. |
Originally Posted by Bud
(Post 15453754)
Originally Posted by joelwhite
(Post 15453826)
t2 should work
this is a t2 ----------------------------------------------------- https://cimg5.ibsrv.net/gimg/www.rct...552244acc1.jpg this is a original rc10t -------------------------------------------------------------- https://cimg2.ibsrv.net/gimg/www.rct...3efe667f7b.jpg this is a early tub rc10 gt --------------------------------------------------------------------- https://cimg3.ibsrv.net/gimg/www.rct...d32d880936.jpg looks to me like the biggest difference is that the gt and t2 have a bit shorter distance front to back length |
oh also this is the the original gold pan buggy setup ( i have tried using it on a truck its not strong enough to push the wheels the heavy t tires tend to engage the servo save to often)
https://cimg4.ibsrv.net/gimg/www.rct...a7487b8544.jpg if i were you i would look for a set of these on ebay they are by far the best out of all of the associated setups (aftermarket alloy with bearings i think dhawk still sells them new) https://cimg9.ibsrv.net/gimg/www.rct...3cee051cfd.jpg yup dhawk sill has them https://www.ebay.com/itm/Aluminum-St...kAAOSw5cNYb6I5 |
I have a set of those on both my GTs. Just have to put the servo saver on the servo.
