Go Back  R/C Tech Forums > General Forums > Vintage Forum
OS 15CV 10A Carb replacement boot >
Old 05-05-2019, 05:12 AM
meno1103's Avatar
Default OS 15CV 10A Carb replacement boot
So I have an old engine with the 10A slide carb which has a dried and cracked dust cover. Engine is in great condition still, been mostly stored, but would like to replace the dust cover without buying and trying multiples. I can't find a replacement for the 10A carb but closest looking match seems to be one for the 10D. Anyone happen to know if this fits, or has one to maybe take measurements? I know the carb body side needs to be <9mm ID, and ball end side needs to be <4mm ID. Compressed length ~10mm, stretched out length ~15mm.
meno1103 is offline
Old 05-05-2019, 10:39 AM
Bud
The os manual lists the 10c as the slide carb for the cv15. https://www.manualslib.com/manual/795847/O-S-Engine-Max-15cv-Series.html?page=25#manual
and..
I found this. https://hopmeup.com/collections/os-e...ducts/osmg5650 It has the same # as the # in the exploded view in the manual. Don't know if this will help you out but it's worth throwing it out there to look at.
Bud is offline
Old 05-05-2019, 03:11 PM
meno1103's Avatar
Originally Posted by Bud View Post
The os manual lists the 10c as the slide carb for the cv15. -snip-
The engine is secondhand, but I broke it in years ago. I believe it was the 15CV-X Hyper version that came with the [older?] 10A slide carb stock (for on-road). Might just have to try out the 10D cover.
meno1103 is offline
Old 05-06-2019, 02:07 AM
Bud
There's a new 10a carb on ebay right now. It's 29 bucks. I wouldn't put that much money in a cv but that's just me. https://www.ebay.com/itm/OS-O-S-Engi...QAAOSwzqdcyczB
Bud is offline
