Novak esc issues
Novak esc issues
Hello I just installed a Novak esc with a airtronics am receiver. I turned it on and the motor just starts spinning fast. I did replace the original 27.095 crystal with my 27.045 crystal only cuz I don't have 2 of the 27.095 ones. Would that matter or does the esc need to be adjusted somehow?thanks
Novak explorer esc
Novak explorer esc
Thanks guys will try it. I just finished an old kyosho touring car and I was hoping to be able to install vintage parts on it too.
ok this is what I know airtronics used specific airtronics crystals .are yours them?.many places online to see the correct crystals and matching # to make sure
No I was using my traxxas ones, that are a different megahertz than airtronics
The wierd thing about the servo is that it's a new one and the wires don't match up the same way as the esc
You can see servo wire above esc the red is in the middle and not on the side, guess I would need a vintage servo too
ok this is one of those you can't fix...….. traxxas will never work..as far as servo. put wires in correct order as rx layout . small tabs on servo plug I used a exacto blade b4 I made my little prong lifter.
Lol ok, it was my only matching pair so I gave it a werl .will order right ones if I can find them
when I looked there was afew sets for sale in places from $4 to like $16 I think..
I can sell you these servos and rx if they are of use to you? lmk I am going to switch it out to futaba.. thanks
Oh snaps those are nice set ups. So I was informed that the crystals have a rx for receiver one and a tx on the transmitter one. I may have bought one if not I will pm you. Thanks for help. I'm sure someone could use those for a vintage class
