Like Tree1Likes
  • 1 Post By the rc guy
Novak esc issues
Old 04-20-2019, 07:19 PM
BladeRunner24's Avatar
Default Novak esc issues
Hello I just installed a Novak esc with a airtronics am receiver. I turned it on and the motor just starts spinning fast. I did replace the original 27.095 crystal with my 27.045 crystal only cuz I don't have 2 of the 27.095 ones. Would that matter or does the esc need to be adjusted somehow?thanks
Novak explorer esc
BladeRunner24 is offline
Old 04-20-2019, 08:42 PM
st_dragn_wagen's Avatar
rx/tx crystals need to match.
and the ESC needs to be programmed. i used to run novak explorer 2's. make sure the throttle trim on the radio is 50/50 and then there's a button on the ESC you need to press (its in one of the holes around the LED hole). it's something along the lines of press and hold the button until the LED starts flashing then release the butting, and pull full throttle (trigger) on the radio and hold until the LED starts flashing and then go full break on the radio and hold until the LED starts flashing, then let the throttle go to neutral and wait for the LED to start flashing. then it will flash again letting you know it's set. it's something along those lines. it's been over a decade sense iv programmed one
st_dragn_wagen is offline
Old 04-20-2019, 10:26 PM
Sir 51D3WAYS's Avatar
You'll want this manual.
Sir 51D3WAYS is offline
Old 04-21-2019, 05:58 PM
Thanks guys will try it. I just finished an old kyosho touring car and I was hoping to be able to install vintage parts on it too.
Old 04-21-2019, 07:53 PM
harry697's Avatar
Trader Rating: 118 (100%+)
Did you try plugging a servo into the receiver and see if it responds? That could help rule out an issue with the crystals or radio.
harry697 is offline
Old 04-22-2019, 04:59 AM
the rc guy's Avatar
ok this is what I know airtronics used specific airtronics crystals .are yours them?.many places online to see the correct crystals and matching # to make sure
the rc guy is offline
Old 04-22-2019, 09:04 PM
No I was using my traxxas ones, that are a different megahertz than airtronics
Old 04-22-2019, 09:05 PM
The wierd thing about the servo is that it's a new one and the wires don't match up the same way as the esc
Old 04-22-2019, 09:07 PM
You can see servo wire above esc the red is in the middle and not on the side, guess I would need a vintage servo too
Old 04-23-2019, 11:01 AM
the rc guy's Avatar
ok this is one of those you can't fix...….. traxxas will never work..as far as servo. put wires in correct order as rx layout . small tabs on servo plug I used a exacto blade b4 I made my little prong lifter.
BladeRunner24 likes this.
Old 04-23-2019, 10:25 PM
Lol ok, it was my only matching pair so I gave it a werl .will order right ones if I can find them
Old 04-24-2019, 05:46 AM
the rc guy's Avatar
when I looked there was afew sets for sale in places from $4 to like $16 I think..
Old 04-24-2019, 08:53 PM
Trader Rating: 14 (100%+)
I can sell you these servos and rx if they are of use to you? lmk I am going to switch it out to futaba.. thanks
TomtenRC is offline
Old 04-25-2019, 09:03 PM
Oh snaps those are nice set ups. So I was informed that the crystals have a rx for receiver one and a tx on the transmitter one. I may have bought one if not I will pm you. Thanks for help. I'm sure someone could use those for a vintage class
