Go Back  R/C Tech Forums > General Forums > Vintage Forum
91 Bolink Eliminator >
Old 06-20-2018, 10:33 AM
Default 91 Bolink Eliminator
Someone gave this to me a few years back. It looks like what I was given is everything I'd need to drive it around, except a body. I'm pretty new to Hobby grade RC, so I'm not 100% sure I know what I'm really looking at. There's a radio in the box, receiver on the car, looks like servo, speed controller, and motor are all there. Gears are there. Idk if this car has a differential or if its just a gear on the rear drive axle. There are foam tires on the car, a few spares in the box. I don't think it has any suspension. A couple of what look like NiMH batter packs. possibly a receiver batter pack. I think there's a charger in the box too. Manual is there too. I'll take some pictures later to post if anyone is interested in seeing what I've got.
My question is, what do I do with this? Would it even be possible to find a body for it? It's a 1/10 scale, would any 1/10 scale body work? Do I just charge it up and see if I can get the wheels spinning as is? Are parts available if I want to rebuild, repair, or restore? Is is possible or worth trying to upgrade it to modern electronics? My goal right now is to ultimately get into racing - is there any class right now I might be able to run in with this thing, with or without upgrades or mods? Not talking being competitive obviously (don't want to just be in the way either), but something I can start to learn with and get experience. At a minimum I guess it'd be nice if I could get it running and use it for parking lot practice?
RCRhino172 is offline
Old 06-21-2018, 09:48 AM
st_dragn_wagen's Avatar
im not an Eliminator expert but i do own one. don't know the year/model but mines a 235mm car. standard 200mm bodies don't fit (the tires will poke like crazy) Protoform makes a 235mm body. it was the only body i could find readily available at the time https://www.racepf.com/on-road-1-10-...clear-body.asp looks pretty good in person. i need to fix the rear t-plate (fiberglass is de-laminating), throw some electronics in it and mine will be a runner again. some parts are still easily obtainable from RJ Speed, and some of the parts from the old RC10L are interchangeable (if you can find them). id say put it together and run it, its seriously dated but it's a good car. it probably wouldn't be a bad place to start as an entree to carpet or oval racing. hell it was a race car in it's day.
st_dragn_wagen is offline
Old 06-23-2018, 09:53 AM
all true... but it will be like driving a 56 Chevy.. ( stock ) and you just might be in the way.
I had one for a short time... 1992..
HAVE FUN.
chuck_thehammer is offline
Old 10-22-2018, 11:57 PM
Trader Rating: 32 (100%+)
For bodies try rccarkings.net they have several wide bodies that should fit. Ebay also has them.
i had one of these back in their hey day. They do have a ball diff at the axle, which was often over tightened. The had two shocks in the back and used little springs in the front axle carriers
The original ones only took saddle packs. Today, you could probably just run a smaller lipo pack, 1S or 2S and be just fine
Hopefully the tires are still good, those are harder to find.
Good luck with it.
67CamaroSS is offline
