Go Back  R/C Tech Forums > General Forums > Vintage Forum
Problems putting in ball bearings for RC10 classic >
Old 03-02-2018, 10:47 PM
Default Problems putting in ball bearings for RC10 classic
I have a 1984 RC10,
buying some ball bearings for it and trying to get rid of the stock bushings.
The rear bushing/ball joint has a bar that keeps it on. I can get it half-way out, but damn if I can grab it or move it with my needle nose pliers.
Any advice?
image is here: imgur.com/a/NluKw
andresjsalazar is offline
Old 03-03-2018, 05:55 AM
the rc guy's Avatar
pull axle pin then push axle . push it thru wrong direction....towards thumb holding location.----->
the rc guy is offline
Old 03-03-2018, 06:16 AM
Trader Rating: 14 (100%+)
That is a “roll pin”, a common way for axles back in the day. Also a giant pita. Essentially you can try to knock it through with a small Allen wrench but we just grabbed them with needle nose and twist and pull or vise grips. It might be easier with it still on the car.
Note that pressing them back in can be fun too, but be careful as they liked to “shoot” off if not aligned correctly and it might be hard to find a original replacement. I suggest a well lit area on a towel so that it doesn’t “bounce” away.
I love the classic stuff but that is one of those things I don’t miss lol.
{tpc} is offline
Old 03-03-2018, 08:28 AM
the rc guy's Avatar
put a piece of dental floss thru the bushing make a big loop a sloppy one then bushing has no place to go far.
Old 03-03-2018, 05:02 PM
delete
Tamiyadan is offline
Old 03-04-2018, 07:25 PM
thanks guys!!
Old 04-14-2018, 11:35 PM
littlevette's Avatar
Trader Rating: 22 (100%+)
file the roll pin's location with a jeweler's round file. don't over do it. file enough material away til the axle slides in and out of the bearing with ease. you could do this the top shaft as well. another problematic area with bearings.
littlevette is offline
