Midnight Pumpkin/ Lunchbox
Can someone who converted to brushless post what motor, esc, and pinion gear you used? Thank you,
Back when I was a young teen I had a Lunchbox and found if you took off the motor mount adaptor and put a conventional 19t pinion, you would get all the speed you could possibly use from a lunchbox. P.S. I flipped my wheelie bar upside down and you keep some on throttle steering.
A few years ago I ran a castle 5700 with stock pinion.
i have one i setup with a redline motor it was 2600 kv cant remember the correct # its a non censored with quark esc 80 amp. with a Tamiya universal motor mount i just went up 1 tooth to a 14.. runs great nothing to insane just fun..motor mount is very old from the 90's its 2 fiberglass pieces one goes on motor the other goes on trans with a adjustment screw at top you can adjust gear mesh..
heres a few i found..https://www.ebay.com/i/302042182540?rt=nc
http://www.xtremercracing.com/Produc...=10055&pID=250
if it was me id stay around just a kV that's close to a hot stock motors kV rate..
