Go Back  R/C Tech Forums > General Forums > Vintage Forum
Picco Integra 1/8TH SCALE. >
Old 12-29-2017, 08:04 AM
Default Picco Integra 1/8TH SCALE.
Has anyone got a couple of new/old stock carbonfibre radio trays plz, allso i need rims , i can get donuts, but need some new rims or does anyone know of any other 1/8th car that doesn't have the mugen MRX offset as these nearly fit but don't. Plz all you guys with the info i need help. cheers.
Tony .
smokeymaronejp is offline
Old 01-01-2018, 09:04 AM
Hi Tony, the original rims are very tuff to find. I know i been restoring 2 Picco RS 6000's for last 18 months on and off....the parts took a while but the wheels are very rare. Try the older OSR1 rims.I think they worked on the Serpent 950/960 cars.
puffdogg is offline
Old 01-01-2018, 09:16 AM
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
Yes they are OS1, and OS2 will not work! it widens the track and for thise that care, it throws off handling.
1/8 IC Fan is offline
Old 01-01-2018, 09:21 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
OS 1 is very close to Picco, probably close enough to make work but it's actually slightly different offset in the rear. I don't remember for sure but I think it was only 2 or 3 mm. Also I think the distance between the pin and the lever on the rear of the Picco was slightly longer so you would have to grind the lever to get it to latch.
wingracer is offline
