Yaiba Spec B4.2 Parts Giveaway!
#139
Recieved all of the Yaiba Racing parts for my Team Associated B4.2 today. Very cool stuff. Can't wait to install everything on the car. It's going to look amazing.
Thanks so much,
Ken Swanson
Thanks so much,
Ken Swanson
#140
It does look amazing. They just need the counter sunk washers and ball stud washers in red and it would be dialed!!!!!!!!!
#141
We've been using the ballstud washers from Tresrey, only difference is the 3mm ID- but if you're using the FT blue 1 and 2mm AE shims they are also 3mm ID, so no biggie there. You do get a bit finer tuning range with them (.5mm, .75mm, 1mm and 2mm shims available.) Red counter sunk washers are easily sourced in the meantime.
#145
master kit?
have you ever considered packing items as a yaiba conversion instead of buying all parts seperately a couple other aftermarket companies do that and it seems popular plus it increases your volume and saves us the racer a little fundage
Good looking products by the way i really like the rear hub design.
#146
Right now we have our prices low enough it would be the same individually or in a "package." Also there are just too many options for the DEX210, B4 series, and RB6 to put them all together. This allows a customer to "custom" build any combination they want at the best price.
#149
The hubs are stellar and well worth the money. Not only do they give more adjustment, but the bearings fit in there snug with no slop yet are easily removable for replacement when needed. Cush has them on both his B4 and B44 and they have been flawless.
#150
Suspended
