BZ-222 Pro 1/10th 2wd Racing Buggy
The BZ-222 Pro is the result of hundreds of customers who bought the original BZ-222 asking for a version with all the option parts included, but we thought we could do better than that, so we took it up a notch and turned what was already a great value entry level race buggy and tweaked it with new stiffer arms, aluminum bulkheads front and rear and fixed the binding issue with the rear transmission that some drivers experienced. Now, not only does the BZ-222 handle like a pro-buggy, it will take the jumps and bumps and spills of off-road racing like a pro-buggy but for a whole lot less money.
Available in 2 different versions: Almost Ready to Run (ARR), and a build-it-yourself kit with a really nice easy to follow instruction manual, this is a great buggy for someone who wants to start racing in the ever popular 2WD class.
We thought the BZ-222 was pretty good to start with, but the BZ-222 Pro is even better, maybe even the best value 2WD race car on the market!
Features:
• Improved belt drive gear box
• Can be converted to a mid-motor chassis layout
• Aluminum adjustable shocks
• Fully adjustable chassis for precision set-up
• Full ball bearing supported drive train
• 3.5mm carbon fibre shock towers
• Adjustable dual side slipper clutch
• Aluminum hubs, steering components and bulkheads
• CVD drive shafts
• Clear polycarbonate body
• 97T 48P spur gear
Specs:
Length: 395mm
Width: 251mm
Height (with rear wing): 128mm
Wheelbase: 289mm
Ground Clearance: 28.3mm
Battery compartment: 138mm x 49mm x 25mm max size
Required:
2ch car radio set
Charger for LiPoly battery
2S 7.4V LiPoly standard/shorty pack
540 / 3650 sized motor
1/10th scale esc
Standard servo
Off road 2.2" tyres
Spray paint suitable for polycarbonate body shell
Get yours today!
i was reading the thread on the non-pro version, there is alot of talk on the belt drive tranny, availability of the belt, having to find industrial supply/belt companies to get replacements.
did..."fixed the binding issue with the rear transmission that some drivers experienced." solve the cause of belt failures?
belts.....still show backorder which still needs fixing and every warehouse including those in xanadu, should show in stock....always
