Go Back  R/C Tech Forums > Commercial/Retail Forums > TrackStar Product Discussion
Basher 4000mAh 6S 65C Hardcase Pack >
Old 12-02-2015, 10:06 PM
Default Basher 4000mAh 6S 65C Hardcase Pack
Basher hardcase packs are heavy hitters punching well above their weight, they can take a pounding and still pack a punch.
The Basher batteries holder higher voltages under load and that translates to higher top end speed, faster throttle responses. They not only look tough they are tough! Tough enough to take the punishing extremes of harcdcore bashing and come back for more.
Basher hardcase packs use completion grade lipoly cells giving the best power punch, so whether its for near vertical wall climbs, power slides or just about anything you can put your basher through, these packs will deliver the goods.
Basher Extreme hardcase packs are quality! They're tough, they're powerful and they're at a price that can't be beat!
Spec.
Capacity: 4000mAh
Voltage: 6S1P / 6 Cell / 22.2v
Discharge: 65C Constant / 90C Burst
Weight: 604g (including wire, plug & case)
Dimensions: 138x47x48mm
Balance Plug: JST-XH
Discharge Plug: HXT4mm
PRODUCT ID: 9067000090-0
Get yours here!
TrackStar1 is offline
