Go Back  R/C Tech Forums > Commercial/Retail Forums > TrackStar Product Discussion
TrackStar Easy Fit Brushless Motor Connectors (3 Sets) >
Old 11-08-2015, 09:00 PM
Default TrackStar Easy Fit Brushless Motor Connectors (3 Sets)
The TrackStar Easy Fit Brushless Motor Connectors are the "must have" item for anyone who has an R/C car. These incredibly handy connectors have a screw that threads through a connector that is soldered to the motor's wire tabs and into a corresponding connector on the power wires. This means when you want to change motors you simply unscrew the existing leads and screw them to another motor. You only need to solder to the motor once which significantly reduces the chance of damage to the sensitive electronics inside. Each pack contains 3 motor side connectors and 3 parallel and 3 right angle wire connectors so you can vary the way the wires run from your motor. Once you have tried this product you will never go back to the old way of wiring up ESCs.
Features:
• Suit for 540size sensored brushless motor
• Wire can weld as stright/45 degree/90 degree out
• Fit for 14 and 12 AWG wire
Specs:
Screw size: M2x12mm
PRODUCT ID: 9171000749-0
TrackStar1 is offline
