Go Back  R/C Tech Forums > Commercial/Retail Forums > TrackStar Product Discussion
TrackStar Easy Fit ESC Connectors (5 pair / set) >
Old 11-05-2015, 05:43 PM
Default TrackStar Easy Fit ESC Connectors (5 pair / set)
The TrackStar Easy Fit ESC Connectors are the new "must have" item for anyone who has an R/C car. These incredibly handy connectors have a screw that threads through the ESC connector and into a corresponding connector on the motor and power wires. This means when you want to change motors or power leads or you want to swap the ESC into another chassis you simply unscrew the existing leads and replace them with the new leads.
You only need to solder to the ESC once which significantly reduces the chance of damage to the sensitive electronics inside. Each pack contains 5 ESC side connectors and 5 vertical and 5 horizontal wire connectors so you can vary the way the wires are positioned inside the chassis. Once you have tried this product you will never go back to the old way of wiring up ESCs.
Features:
• Suit for most 1/10 brushless ESC
• Wire can weld as stright/45 degree/90 degree out
• Fit for 14 and 12 AWG wire
Specs:
Screw size: M2x12mm
Base pole diameter: 2.8mm
PRODUCT ID: 9171000763-0
TrackStar1 is offline
