TrackStar 1/8 Set-up Board
TrackStar 1/8 Set-up Board is made of rigid acrylic to give you an accurate benchmark to work from and is designed to work with the TrackStar set-up tools as well as many other makes. The TrackStar designers have made this board as versatile and accurate as possible and still be able to withstand the rigours of being at the track, on the work bench and the many journeys in between.
Check out the other great set-up tools from TrackStar that will go with this board.
Features:
• Provides you a flat surface for chassis measurement
• Suits both 1/8 on and off-road
• UV protected painted background with track width gauge
• 1mm and 2mm stepped markings
Specs:
Size: 540mm x 341mm
Thinkness: 10mm
Weight: 2120g
Material: Acrylic
9171000755-0
