Go Back  R/C Tech Forums > Commercial/Retail Forums > TrackStar Product Discussion
Turnigy TrackStar Sensored Brushless 17.5T Motor >
Old 11-05-2015, 04:54 PM
Default Turnigy TrackStar Sensored Brushless 17.5T Motor
Turnigy TrackStar Sensored Brushless Motors offer race winning performance at an incredible price!
Featuring a CNC alloy motor can with dynamic cooling technology, hand-wound high purity copper windings and powerful sintered neodymium magnets, you won’t find a better priced motor of this calibre anywhere else! the new high RPM motors also feature adjustable timing which allows for fine tuning the performance of your ride while the sensor ensures smooth start-ups and acceleration. If you thought the original TrackStar Brushless Motors were good, the Outlaw series will blow you and your competitors away.
The TrackStar brushless motors make a great upgrade or competition motor for 1/10th short course trucks, buggies, touring cars or anything else that uses 540 size motors.
Features:
• Super light weight body (14g)
• Maximize cooling effect
• 2 sensor port position
• Adjustable timing angle
• Balanced Sintered Neodymium magnet rotor
• Increased magnetic force for improved torque
• Rotor diameter steps from 12.5 to 12.3mm to ensure maximum rpm
Specs:
KV: 2189kv
Max Current: 33 amps
Max Power: 245 watts
Idle Current: 2A
Shaft: 3.17mm
Weight: 170g
Cell Count: 1~2S Lipoly
PRODUCT ID: 9192000261-0
TrackStar1 is offline
Old 12-17-2015, 12:31 PM
Trader Rating: 28 (100%+)
Oval guys at the track I race at are buying a dozen of these to do a handout class of trucks. They're going to set them all up the same, glue em together, and keep em locked up in between races. Should be pretty cool
jbrow1 is offline
