Can someone fix my I charger 106b
These type of switch/buttons are integrated with the circuit board.
They would be almost impossible to replace. If they are intermittent , I
would think that it could be dust infiltration . I would take it apart and try to
clean it first. This is my guess!
Try Shields electronics in Knoxville on Middlebrook PK.
Ok so these are the buttons I bought, the 5mm is the height of the switch button and the I charger must use like 20mm so I just cut the post down and glued the old post to the new switch... Works perfect. You do have to be quick with the heat and carefully bend the tabs to line up but if I can do it anyone can. I used a cheap 60w iron to do it.
