Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 12-21-2008, 12:02 PM   #11446
Trader Rating: 6 (88%+)
Originally Posted by hpisims View Post
Bill you have a PM about my order
back at you
comming soon MOTORHEAD RC MOTORSPORTS...........
BILL.D is offline   Reply With Quote
Old 12-21-2008, 12:03 PM   #11447
Originally Posted by RaceAce701 View Post
hey bill any updates on my 0rders
if the dont go out soon we have 2 have a talk i might just have u bring it ball 2 the ft race
we can do that. we are just trying to get it all togeather sorry
for the delay
Old 12-21-2008, 02:45 PM   #11448
RaceAce701's Avatar
Trader Rating: 86 (99%+)
Bill u Got PM
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 12-21-2008, 05:33 PM   #11449
morris's Avatar
Trader Rating: 40 (100%+)
bill,
i also will be attending the ft race.tring to hook up with raceace and follow him there.
be also looking forward to meeting you for the first time.....
lata
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-22-2008, 07:25 AM   #11450
hpisims's Avatar
Thanks Bill for getting me the horsepower needed to make the A main this weekend FASTEST 13.5 I have ever used and the batteries as always have killer numbers. Thanks again bro.
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 12-22-2008, 01:51 PM   #11451
KHoff7's Avatar
Hey Bill will you have any Duo 13.5's at mimi's this weekend?
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 12-22-2008, 07:53 PM   #11452
Glowster21's Avatar
Trader Rating: 116 (100%+)
Originally Posted by DRPSignsNGrafix View Post
Any team guys needing graphics for the snowbirds. Get your order in soon. I will bring them to the birds or get them shipped out to you. FT team guys get a %20 dicount. Email me any requests at
[email protected]
Email sent...Thanks
Glowster21 is offline   Reply With Quote
Old 12-22-2008, 07:57 PM   #11453
i will be out of town all week for x-mas
Old 12-23-2008, 04:52 PM   #11454
B4 Racer's Avatar
I would like to wish all the Team Full Throttle Drivers a Merry Christmas and a Happy New Year.
Later, Donnie Taylor
Dallas Tx.
B4 Racer is offline   Reply With Quote
Old 12-23-2008, 08:47 PM   #11455
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any updates on the 12 scaler?
R
UltegraSTI is offline   Reply With Quote
Old 12-24-2008, 02:12 PM   #11456
Thumbs up Set ups
Hello everyone, sorry for the long delay in my post. I have done a lot of testing thanks to Big L. This car has a very big sweet spot. You can run the car with multiple set ups and it will drive like a cadillac. Standard issue on the mod ride is a .075 or spring steel. Use the .007 shims to controll your roll and rotation. By rasing the pivot ball equally you will stop chassis roll just like your touring car. By angling the the pivots (front higher) this will make the intial steering more aggressive and will rotate more. Clev. I ran .007 in the rear and .014 in the front. For damping. I prefer the Corally red syrup it last longer and takes less also there are 3 visc. I actually found the .075/spring steel was the most consistant and easy to drive. With this t-bar use 25-35 wt. oil grn or silv center spring. I actaully turned faster laps locally with the .060 and red side springs but it was not as consistant. I will work with it more at the birds under high bite. Close attention has to be given to the the damper tubes when using the springs. Release the tweak screws on the t-bar and adjust the tubes to have very little preload and equall preload. You will have to trim the ball ends about 1mm. You should be abel to look at the bottom of the lower pod plate and set it flush on both sides to the chassis. If it needs adj. simply cut the ball end or unscrew one. Now go back and set your preload on the t-bar tweak screws to stay touching at full travel. Here is a little tip from a former WC. Take ( with saftey glasses on) a couple of old xacto nife blades and break off the ends( the part that goes in the handle), dremel them straight. Glue them under your tweak screws to the graphite chassis. This will give you a more positive tweak setting and save your graphite. Use the green or silver center spring but with 30 - 40 wt. Stock racers might want to try a heavier center spring witht the softer t-bar setup. Both set ups I prefer 1 to 1.5 mm of droop in the rear and the front shock mount is 21 mm from the chassis to the center of the pivot ball (stnd associated mount with a med ball studd). I have been using the old associated front end with the 10deg. front blocks, full caster, .018 with .1 or .2 mm of droop I really like .1, using the heavy Corally syrup with the KSG grooved pivot balls for damping. It is very important to set the droop with OUT the damping fluid applied. Runing 1 to 1.5 deg. of camber and 1 to 1.5 deg. of tow out. I also made a graphite brace that has a little free play to flex out so the front end is braced and should not tweak. Tire Size Fronts 42mm rears 43 on Parma's. Combinations I recomend Double pink fronts or Parma Mag. Glue the outside. Rears Yellow or Mag. Corall on Parma's. Glue the bead. Stock racers might want to try other fronts. 3.5 mm on the ride height. Hopefully this helps everyone. I am working on drawings for new performance enhancement products for the current car and invisioning an updated more stylish looking components. Best of luck to everyone remeber if you cant run it full throttle then leave it on the trailer. LOL
TTYL CD RACING USA IFMAR WORLD CHAMPIONS
CDSUPERPRO is offline   Reply With Quote
Old 12-24-2008, 06:12 PM   #11457
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
WOW!! that's a long post
from the Connors family to all the R/C family out there have a very Merry Christmas
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 12-25-2008, 08:14 AM   #11458
hpisims's Avatar
Merry Christmas to all of Team FullThrottle.
J.SIMS
www.ovrccc.com
Old 12-25-2008, 08:20 AM   #11459
Glowster21's Avatar
Merry Christmas to the FullThrottle Team!!!
Bill D....YGPM
Old 12-25-2008, 09:24 AM   #11460
Send a message via AIM to T. Taylor
I say once again HAPPY HOLIDAYS to all of FULL THROTTLE. May 09 even better than 08 for all of us.
T. Taylor is offline   Reply With Quote
fullthrottle 3800s sale BILL.D Other Items: For Sale/Trade or Wanted to Buy 4 01-25-2009 09:23 PM
FULLTHROTTLE CARPET CHAMPIONSHIPS BILL.D Racing Forum 380 11-12-2008 07:03 PM
Fullthrottle Motor sports RC MARKET Buyer/Seller dispute and Feedback discussion forum 6 09-20-2008 03:01 AM
2007 fullthrottle motorsports onroad CHAMPIONSHIP'S BILL.D Racing Forum 445 06-12-2007 09:33 AM
fullthrottle motorsports 3800s blow out sale BILL.D R/C Items: Wanted to Buy 2 07-20-2006 11:41 AM
