Like Tree310Likes
R1 Wurks brushless motors
Old 03-21-2024, 09:22 AM
  #1336
I'm pretty sure most of the support is on their facebook page.
malkiy is offline
Old 03-24-2024, 08:58 PM
  #1337
staiguy's Avatar
I emailed them about getting an invoice for a sensor board replacement. Email response was quick and easy. They have their contact info on their site towards the bottom
staiguy is offline
Old 05-19-2024, 02:04 PM
  #1338
I have one of the "Hand Picked Rotor, Aligned Sensor" motors, and it's a weapon. Should I adjust my timing as normal when tuning the car, or leave it as set by the OEM?
drumondo is offline
Old 05-19-2024, 08:37 PM
  #1339
Johnny Wishbone's Avatar
The timing set from the factory is based on a safe setting that is made so as to not damage the motor. If you have a tuning method you should use that.
Johnny Wishbone is offline
Old 05-20-2024, 02:24 AM
  #1340
gigaplex's Avatar
The last R1 motor I bought came at a setting that drew 9A under no load. It was not particularly safe.
gigaplex is offline
Old 05-20-2024, 03:13 AM
  #1341
I知 running a 25.5 v21-s in my F1 currently geared at 86 spur 32 pinion on high grip black carpet. The timing is about 46* on my Motolyser. Down the straight I can keep up with the faster drivers but in the infield they just pull away from me. Fast guys lap times are low 12痴 I知 mid to upper 12 second range. Am I over geared? Am I under geared? Please help
Kruss45 is offline
Old 05-20-2024, 05:48 AM
  #1342
STLNLST's Avatar
Trader Rating: 32 (100%+)
sounds more like car setup rather than motor. You could be scrubbing speed in the corners. You could always drop a tooth on the pinion to see if you gain a little in the infield.
gigaplex and OffRoadJunkie like this.
STLNLST is offline
Old 05-20-2024, 08:49 AM
  #1343
OffRoadJunkie's Avatar
I agree on that one. Sounds like the other guys are pulling out of the corners faster, so you need more torque.
OffRoadJunkie is offline
Old 05-28-2024, 05:19 AM
  #1344
I知 currently running a
21.5t R1-V21s and a R1 17.5t V21-s
what gearing and timing should I use for asphalt touring ?
Aurora_007 is offline
Old 05-28-2024, 09:26 AM
  #1345
R/C Tech Elite Member
EricW's Avatar
I'm looking for some help on this as well.
I'm running on asphalt as well, our straight is about 80 feet. I'm using a 3racing Cero Sport, it has a 1.9:1 gear ratio. Traction is mid-high
EricW is offline
Old 06-04-2024, 02:54 AM
  #1346
Recommend starting around 3.4 fdr for 21.5, and 3.8 to 3.7 fdr for 17.5. Timing should be set to 40* on the endbell. I wouldn't ever exceed 42* on the endbell, the v21s doesn't like a lot of timing so 40 is usually the sweet spot. Most of the tuning should really be with the gear rather than timing. If you have a good fan on the motor, temps around 180* are fine. The big thing is that the motor cools down quickly after the run, so keep the fan running while you turn marshal. The v21s stator can easily handle this.
davidl likes this.
punkboy is offline
Old 06-04-2024, 11:13 AM
  #1347
EricW's Avatar
Appreciate the feedback but I have to ask. Is that FDR correct for 21.5? Right now, I'm running 101x41 with a transmission ratio of 1.9:1. That puts me at 4.68 FDR, getting to 3.4 would be a significant change in gearing.
EricW is offline
Old 06-04-2024, 11:34 AM
  #1348
Trader Rating: 43 (98%+)
Obviously your recommendations are for a two cell application. Do you have any single cell experience you would share?
davidl is offline
Old 06-04-2024, 11:55 AM
  #1349
4.68 on 101x41? That seems very under geared or your motor is unusual. On my R1 shorty 21.5 I was around 3.8 on a 90x40 carpet track.
malkiy is offline
Old 06-04-2024, 04:57 PM
  #1350
gigaplex's Avatar
Your ratio is roughly what I'd be running with a 13.5T motor on a large outdoor track. At the very least I'd be dropping down to 3.8 FDR for your sized track with a 21.5T. 3.4 is where I'd start for 21.5T on a larger track.
gigaplex is offline
