Like Tree310Likes
R1 Wurks brushless motors
Old 07-27-2016, 04:09 PM
  #121
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
A lot of folks are testing the waters with v11. Both are fast... And choices can be confusing
V7 is my tc 17.5 and 13.5 goto motor
The prior v9 is/was amazing in 1/12... Gotta start v11 testing for 1/12 this winter...
hanulec is offline
Old 07-27-2016, 07:32 PM
  #122
Thanks for the info! I will start with the V7 or now.
hcw5733 is offline
Old 07-30-2016, 03:40 AM
  #123
Sam Isaacs's Avatar
Trader Rating: 29 (100%+)
I have been able to try both the V7 and V11 motors in the spec TC classes (17.5 and 13.5) and have been very happy with the performance of both. I cannot pick which one I prefer, but I generally think the V11 may be a slightly punchier motor whereas the V7 a more top end motor. Both great options.
V7 is the gold-standard and what most people know/can help with, so for that reason it might be the route to go.
Sam Isaacs is offline
Old 07-30-2016, 05:29 PM
  #124
JimmyMac's Avatar
I run the V11 in 17.5 12th scale and it's been pretty good. Prior to that I ran the V9, but I think the V11 has a slight edge on it. My V9 13.5 was a beast. Would love to see what a V11 can do but we don't run that anymore except for WGT.
JimmyMac is offline
Old 08-01-2016, 07:52 AM
  #125
vivo quevas's Avatar
Trader Rating: 19 (100%+)
Can you guys tell me what the IR is on the R1 high output batteries in perticular 6000 mah. I was wondering if these are designed for spec racing?
vivo quevas is offline
Old 08-01-2016, 08:07 AM
  #126
Mine is in the 1.2~1.4 range after a 30 amp discharge and a 20 amp charge. This was recommended to me by Mr.R1 himself at Tamiya track.
greenpea76 is offline
Old 08-01-2016, 02:47 PM
  #127
Sam Isaacs's Avatar
If you are running 17.5 or 13.5 TC, you would want the 7600 90C pack. I've seen IR's as low as .9/1.0 per cell.
Sam
Old 08-01-2016, 05:22 PM
  #128
I run VTA and USGT 6000 is legal limit in VTA.
.9/1.0 is very good.
Old 08-01-2016, 05:50 PM
  #129
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
subscribing to see when the 25.5 motor comes out.
JEFFs SC10 is offline
Old 08-08-2016, 01:34 PM
  #130
Just bought a V11 17.5 for 1/12 pan car (blinky mode) Whats a good end can timing setting to start with. I dont have a motor analyzer so I cant test what 0 on the motor actually is. Thanks...
taz169 is offline
Old 08-08-2016, 01:43 PM
  #131
Trader Rating: 90 (100%+)
V11 17.5 for 1:12: Start around 40* timing on the can and a 95 rollout. This should get you started and you can adjust accordingly from there. Good luck.
RBLove is offline
Old 08-08-2016, 04:03 PM
  #132
GREAT just what I wanted to know............. Thanks.
taz169 is offline
Old 08-09-2016, 12:08 PM
  #133
V11 setups:
https://www.r1wurks.com.au/pages/r1-wurks-v11-tech-tips
malkiy is offline
Old 08-14-2016, 09:24 AM
  #134
politpot's Avatar
this motor is very good and nicely built, extremely speedy and has a ton of torque.. the only hindrance is the cogging problem on the 2017 version with some ESC specially the REDs brand and muchmore ones.. rotor size and dimension is basically a photocopy of team trinity d4.. so not a problemif you want to change it and make it even stronger.. bought 2 of these, tried once then sold it the day after.. otherwise very strong motor
politpot is offline
Old 08-14-2016, 03:36 PM
  #135
In 12th scale I found that anything over 45* the V11 17.5 motor will cog with a SMC esc.
RBLove is offline
