Like Tree310Likes
R1 Wurks brushless motors
Old 05-06-2021, 06:55 AM
  #1186
Originally Posted by Johnny Wishbone
Hi James,
I guess in a perfect world having all the sensors exactly the same would be nice, no doubt. I can't say why there is one that is different than the others, but I suspect its much like when they set them on the board for timing, which will have variances.
The way you describe your gap setting it sounds like your trying to do it inside the motor, and if so, I understand your problem. I can tell you when I set the gap, I do it entirely out of the stator. Simply put some shims on the timing side of the rotor and place it in the timing side of the assembly, stand it up and check the gap all around, give it a spin and make sure the gap is good. Now that you have established the shim required for good gap, you can assemble the motor with those shims on the timing side. Go to the other end of the motor a place the big shim on the rotor and put the end plate on the motor. Now check to see if you have any end play, you want a very small amount. If the play feels good put the screws in for final assembly, go back and check the end play as the screws will probably take a little more play out. If it tightens up, reset the spacers on the non timing side of the motor till you get just a small amount of end play. It may take a couple tries.
Now as far as the long rotors go and the timing boards go, a couple things to take into consideration. The timing board is shorter than the previous ones, and the rotor is longer (obviously) the intent with this was to be able to set a good gap for the timing, but also take advantage of getting the rotor more centered into the stator, which should net a better operating motor. Don't be led astray by information that the tightest gap is the best. There are many variables that are involved with the whole gap idea, but too close isn't necessarily good either.
Hope that helps.
Wow! This helps a lot! I feel so stupid now but who knew. No one has ever explained to me how to do this like you just did. This is the kind of support I was hoping to get in the first place. You are a great ambassador for R1 sir!
I wasn't looking for a refund or anything like that with my initial email to R1 but just wanted to make sure there wasn't a problem and that I didn't ruin another sensor board. The response I got was frankly a little abrupt and seemed uncaring. Your explanation takes all the guess work out of it. Would go a long way to add something like this to the rotor kit maybe.
Thanks for your help!
VanBee is offline
Old 05-24-2021, 11:43 PM
  #1187
midse's Avatar
Originally Posted by gigaplex
Are you suggesting that NASA never has failures? And that Hobbywing aren't one of the better name brand ESCs out there? They're one of the most popular brands available at this time.
Very old post.... but only 2 of those brands didn't have overheating issues there.
Aveox USA is a defence spec. controller manufacturer. Their and other early brand controllers were copied.
midse is offline
Old 06-13-2021, 01:08 AM
  #1188
choisan's Avatar
may someone advise if the digital 3 mod could use 1s lipo? or must support 2 s only? saw different websites, they mentioned differently.
choisan is online now
Old 06-14-2021, 08:04 AM
  #1189
Johnny Wishbone's Avatar
The original D3 was 1s/2s, unfortunately the new D3 is 2s only. I believe that a 1s is in the works, but demand has it pretty low on the priority list.
choisan likes this.
Johnny Wishbone is offline
Old 06-14-2021, 05:54 PM
  #1190
gigaplex's Avatar
Is there active development on the Digital 3 line? I believe the OEM was Graupner and they've filed for bankruptcy.
gigaplex is offline
Old 06-15-2021, 07:19 AM
  #1191
yup. Sadly another.
Yokomo have changed OEM provider for their new ESC, R1 will have to do same.
cplus is offline
Old 07-18-2021, 07:47 PM
  #1192
Vantard's Avatar
Default R1 17.5 v21 gearing help
Does anyone have any advice for gearing a custom works sprint with v21 17.5, i believe the gear box is 2.4:1 and the spur is an 81.
I tried 26,27,28 pinion and the hottest I can get the motor with 35 can timing, 25 boost and 10 turbo is about 115.
others are running 27 tooth pinions with theyr setups and other motors
Vantard is offline
Old 07-19-2021, 03:08 AM
  #1193
bertottius's Avatar
Trader Rating: 28 (100%+)
Maybe try can timing at 40 or more boost. What ESC are you using?
bertottius is offline
Old 07-19-2021, 05:48 AM
  #1194
Vantard's Avatar
Tekin rsx.
Vantard is offline
Old 07-19-2021, 06:39 AM
  #1195
bertottius's Avatar
Tekin rsx.
I would also make sure your epa is 100%. I'm not used to the Tekin esc line. I run mostly Hobbywing esc's. I would take the turbo out completely and just add boost.
Old 07-19-2021, 07:52 AM
  #1196
Vantard's Avatar
Yea thats the thing, my epa is 100% but when I datalog the throttle comes up at 72% at wot. Its been bound so Im not sure why thatd be.
it is a new radio, m17.
Vantard is offline
Old 07-19-2021, 07:58 AM
  #1197
Vantard's Avatar
I will try the boost only and can at 40 degrees, the other r1 I have seems to run best at 47.5 though it has aligned sensors.
I have new esc, aligned motor and battery coming from r1, I had just hoped to be close with this expendable motor before I put better stuff.
the tekin is very old and may not be getting along with my newer radio if thats such a thing
Vantard is offline
Old 07-19-2021, 08:21 AM
  #1198
bertottius's Avatar
Have you tried to redo the binding process? I've had them fall out for no apparent reason before...something else to check
Old 07-19-2021, 06:28 PM
  #1199
I believe that on Tekin data logging, you should see 80% on the graph. 72% is a little low, I would check to make sure all the settings are correct on the transmitter, check to make sure your setup for 70/30 is a good place to start.
Old 07-19-2021, 10:55 PM
  #1200
gigaplex's Avatar
Have you recalibrated the ESC after changing radio?
gigaplex is offline
