R1 Wurks brushless motors
#1068
I know ROAR fixed this, I thought BRCA was supposed to follow suit.
https://www.liverc.com/news/announce...QkBp38txOMxkuc
Ahhh nm...clarified here...stator lengths were changed and were too short for the European versions...yikes...
https://www.liverc.com/news/announce...Approved_List/
#1070
I have found great benefit in running the 1650 in most situations.... a larger flowing track may be better suited for the std rotor, but there is definitely no disadvantage of the 1650 when geared correctly.
Changing the Rotor will not change the alignment
#1072
I know someone from R1 has got to be reading this thread, can we please get a updated sensor board? No reason a two race old motor that's never seen over 120 degrees should pop one, it sucks even more when I was the TQ and three other drivers also lost one during the day.
#1073
What kind of deviations are people seeing on v21 motors between endbell and actual measured timing figures?
#1074
#1076
If your looking for quicker response to technical questions, R1 rarely come on RCTECH, its best to post your questions on the R1 Wurks face book page or contact them directly via e-mail.
#1077
I believe the door was shut on R1 being able to come up with a solution when the 3 year ban was applied. Since they can't submit anything for 3 years they have no way to get a corrected version in the approval process. This is a issue you should bring up with BRCA or whomever your sanctioning body is since its their call for the 3 year ban.
#1078
#1079
They have a pretty good warranty process, you just have to get a RMA off the website.
Did you re-shim the motor, or did you have it apart? If you re-shimmed the rotor and are using teflon shims on the sensor board side I would get rid of them, especially in off road applications, but tank slappers in onroad can have the same issue. The "squish" of the teflon spacers is enough, that if your tight on the sensor board side, it can take out the sensors, even a light scuff will be enough damage to have a board failure.
#1080
I was running a State Race in Florida and also blew a sensor board in my V21. I put in my V16 and did pretty well, but I have blown so many sensor boards at big races that I am done with R1. I do not want to have DNF's at big races. And for the record, I know what I am doing.... I finish on the podium with stiff competition many a time...………….
