Like Tree310Likes
R1 Wurks brushless motors
Old 12-20-2018, 11:32 AM
  #901
Have anyone tried the double ceramic bearings ? What do u think about them ?
Ggrant is offline
Old 12-20-2018, 02:53 PM
  #902
tbrymer's Avatar
I assume you mean the double ceramic "full" bearings? I've tried them and although they seemed to work great, they made more noise and required lubrication after every 3 races, therefore I prefer the non-full double ceramic bearings. They are awesome and cost less. Just my 2 cents.
tbrymer is offline
Old 12-29-2018, 10:54 PM
  #903
Trader Rating: 43 (100%+)
Just got the new 17.5 V21 R1 motor.
I race at this track. .. racing a Yokomo BD8
what timing and gearing should I start with.
My Tekin Spec R runs nicely with an FDR of 4.2 gearing around 96/38
Phillip F is offline
Old 12-30-2018, 12:15 AM
  #904
Moderator
Pro ten Holland's Avatar
Default V21 13.5 1s rollout and timing advice
Hi all,
I recently purchased a v21 13.5. It's the BRCA approved version.
I will run it in my 12th scale car on a relatively large track (racing arena Limburg).
can anyone suggest a good starting point for timing (or amp draw setting on a motor checker) and rollout ?
thanks in advance
Pro ten Holland is offline
Old 12-30-2018, 10:43 AM
  #905
tbrymer's Avatar
https://youtu.be/qo8uWT2NogI
Mine was a rocket at 4.10 ratio and 50 degrees timing. I run 17.5 blinky touring car though. Not sure if you are running blinky mode or not. Also, your track looks slightly bigger than my home track and more flowing.
I'd probably start around (3.90 - 4.00) and (48-50) degrees timing if I was going to run on your track. (Assuming 17.5 blinky)
tbrymer is offline
Old 12-30-2018, 01:45 PM
  #906
yep I run blinky 17.5t turn too.
Old 12-30-2018, 02:56 PM
  #907
tbrymer's Avatar
Here's a link to our track. We change the layout about every 3 or months and the website hasn't been updated with new pics, but it gives you an idea of the size.
https://www.azscaleracers.com/
tbrymer is offline
Old 12-30-2018, 03:00 PM
  #908
https://www.azscaleracers.com/?fbcli...YTIlKoXmp2_Jqw
sweet... almost the same. What temp are you getting with your R1 V21 17.5 after 5 minute qualifier?
Old 01-04-2019, 07:49 PM
  #909
Team, After some gearing advice for 17.5 4wd. I have on order V21 17.5 to run in a B64D, any idea on what a good starting gear ratio would be? Track is fairly large as we run 8th scale as well on same track.
Thanks in advance.
Tmack is offline
Old 01-09-2019, 03:17 AM
  #910
bertottius's Avatar
Trader Rating: 28 (100%+)
Does anyone have a timing position for the V21 17.5 with the stock rotor for 1/12? I have a good idea where it needs to be but I just wanted to compare and see what others are running them at.
bertottius is offline
Old 01-10-2019, 08:17 AM
  #911
Ty-bo's Avatar
there are so many variables.... a good starting point is 42* and an 78 rollout
depending on your track though.....
Ty-bo is offline
Old 01-10-2019, 08:18 AM
  #912
Ty-bo's Avatar
Iím at 3.4a and 88 RO
Ty-bo is offline
Old 01-10-2019, 10:05 AM
  #913
bertottius's Avatar
Thanks! You test amp rating on a motolyser?
Old 01-10-2019, 07:23 PM
  #914
Ty-bo's Avatar
Yes sir.... typically 3.0 - 3.5 draw
check your temp often to start.... should always keep the temp sub 160 to ensure longevity of the rotor. My 1/12 motor is coming off at 135-140
bertottius likes this.
Ty-bo is offline
Old 01-11-2019, 10:22 AM
  #915
carkillaii's Avatar
ETA on V21 25.5?
iTz Nicholas72 likes this.
carkillaii is offline
