Like Tree162Likes
R1 Wurks brushless motors
Old 11-07-2018, 05:00 PM
  #826
Trader Rating: 14 (100%+)
Originally Posted by tbrymer View Post
Yes. I have a friend that put his 1650 rotor into a V21 this past weekend and it worked fine. Not sure if he had to change the shimming or not.
...but was it fast?
kchura is offline
Old 11-07-2018, 05:01 PM
  #827
tbrymer's Avatar
Originally Posted by kchura View Post
...but was it fast?
Yep. Out of the ten cars in the race the top three were within .1sec for fast lap, and he had the second fastest lap time.
kchura likes this.
tbrymer is offline
Old 11-08-2018, 06:15 AM
  #828
dirt42fan's Avatar
Trader Rating: 148 (100%+)
In what class of racing?
dirt42fan is offline
Old 11-08-2018, 11:01 AM
  #829
tbrymer's Avatar
It was 21.5T motor in USGT class.
tbrymer is offline
Old 11-13-2018, 06:59 AM
  #830
theproffesor's Avatar
Trader Rating: 59 (100%+)
Any word on V21 25.5?
theproffesor is online now
Old 11-14-2018, 01:10 AM
  #831
Super Moderator
nexxus's Avatar
Trader Rating: 309 (100%+)
Had to double check my results on this one
Game Changer?
nexxus is offline
Old 11-14-2018, 01:20 AM
  #832
Widowmaker's Avatar
If those numbers are spot on its not a game changer, it's a game owner.
carkillaii likes this.
Widowmaker is offline
Old 11-14-2018, 09:33 AM
  #833
Riketsu's Avatar
Trader Rating: 33 (100%+)
What did you use to test this?? Minipro or MC2 Dyno?? How did you set the timing on each one?? to 6A or to max efficiency??
Game Changer?
Riketsu is offline
Old 11-14-2018, 10:18 AM
  #834
I know this is the motor section but does anyone know the intended application of this battery pack. I know typically 6000ish for mod, 8000ish for stock but this is 10,000 and only 50C?
https://r1wurks.com/collections/batt...aphene-battery
DavidNERODease is offline
Old 11-14-2018, 11:02 AM
  #835
bertottius's Avatar
Trader Rating: 22 (100%+)
Probably good for stock too. I'll bet they hold voltage a lot longer.
bertottius is online now
Old 11-14-2018, 01:09 PM
  #836
Seriously?????????????????? $120 for a toy car battery
Are you guys nuts?????????????
it is supposed to be fun, not cutthroat. (As I contemplate getting 4 of 'em)
Oh yeah, I forgot. it's racing
How fast you want to go? How much money you got..??..
idbdoug and evox88 like this.
mediumquick is offline
Old 11-14-2018, 06:09 PM
  #837
Super Moderator
nexxus's Avatar
Using a Mini Pro dyno, Zombie 8200mah pack repeaked before each run. Timing set to the point I feel is optimal (where any further advancement of timing increases amp draw disproportionately to rpm), sorry I think the Nick Adams 6A method is cute, but assumes all motors are equal and behave equally, which they don't.
two shoes likes this.
nexxus is offline
Old 11-14-2018, 06:18 PM
  #838
Riketsu's Avatar
Thanks for the answers nexxus!!
Can you tell us the timing at this point of each of the motors??
also, did you have to purchase a license for Minipro dyno to be able to export it to that software?
Riketsu is offline
Old 11-14-2018, 06:30 PM
  #839
Super Moderator
nexxus's Avatar
You need to purchase RC Crew Chief which can import Mini Pro dyno files.
As for individual timing on the motors, it varied motor to motor but generally between 45-50 on the newer motors, certainly not above 50. That is actual timing on a motolyser, not what the endbell or the skyrc analyser says.
nexxus is offline
Old 11-14-2018, 06:40 PM
  #840
gigaplex's Avatar
While I don't fault your method, I can't really tell from that graph if it's an improvement over the motors currently run around here (mostly R1 v16 and Monster Max) as they're not in the comparison.
gigaplex is offline
