Like Tree98Likes
R1 Wurks brushless motors
Old 02-16-2018, 09:23 AM
  #601
kaistas's Avatar
Originally Posted by Antimullet View Post
Try adding timing on the can a degree or two at a time as well. Or find out your internal amp draw as is, then bump it up a few tenths, try again until you get it in the sweet spot. It should be around 150-160 coming off after a main. I have always found R1s like to run at higher heat levels than other cars.
Is this 25.5 VTA, F1, or TC?
25.5 VTA/Scale Spec.
kaistas is offline
Old 02-16-2018, 11:38 PM
  #602
Gravity Dodger's Avatar
4.5 for vta seams to tall, I would assume you'd be 3.6-3.7 depending on track size. I know at Champs this year some drivers were at 3.5-3.6 for vta and if memory serves me correctly that was a hundred foot back stretch. I'm new to R1 but anything over a 3.8 looses a ton of top end an motor appears to be at full revs almost entire race.
Gravity Dodger is offline
Old 02-17-2018, 08:44 PM
  #603
For reference, we are running 3.2 - 3.3 with the current Reedy 25.5 motor on a medium size track.
4.5 is 13.5 territory.
Antimullet likes this.
belewis01 is offline
Old 02-18-2018, 10:10 AM
  #604
Trader Rating: 18 (100%+)
I was running 3.6 on a small technical track in VTA meanwhile the Motiv guys were in the 3.8 range. Definitely try gearing it up...
iTz Nicholas72 is offline
Old 02-25-2018, 12:59 AM
  #605
Dan
Dan's Avatar
Trader Rating: 52 (100%+)
Anyone experiencing fade on the V16 25.5 motor with 12.3mm high torque rotor?
Running 8 minute mains in F1 on a small 80x40 black carpet track. Motor never overheated, always running with a fan. Starts off great the first 3 or 4 minutes, then fade is quite noticeable. Never exceeds 150F. I'm getting fade as much as 3 or 4 tenths off my last 2 minutes versus my first 2 minutes. A bit more than I'd like.... I upgraded to a higher capacity shorty battery too so I know that isn't the issue. Timing about 55 deg on endbell and 3.07 gearing.
OVA likes this.
Dan is offline
Old 02-25-2018, 07:20 PM
  #606
Jorge T's Avatar
Trader Rating: 14 (100%+)
I suggest back off some on timing.
I run my F1 25.5 at 48*set on motolyser at 2.69FDR and motor barely get 135*F. Track is blk carpet 95x40ft.
vivo quevas likes this.
Jorge T is offline
Old 02-25-2018, 09:00 PM
  #607
Dan
Dan's Avatar
I unfortunately do not have a motolyzer. What is the marking at on the endbell? Close to 48? Thanks again.
spammy likes this.
Dan is offline
Old 02-26-2018, 05:12 PM
  #608
theproffesor's Avatar
Trader Rating: 58 (100%+)
What is everyone using to set timing, check amp draw, etc. looking to start doing some motor work and want to get the right equipment.
On that same note, what is a good timing setting for 25.5 TC/VTA and 21.5 TC/USGT. Also amp draw, what am I looking for?
theproffesor is offline
Old 02-26-2018, 08:21 PM
  #609
Jorge T's Avatar
On mine it is close to the 50 mark.
OVA likes this.
Jorge T is offline
Old 03-01-2018, 08:28 PM
  #610
idbdoug's Avatar
Trader Rating: 33 (100%+)
A little setback with planned R1wurks aluminum endbell/timing screws and long aluminum stator screws. There was some issues with the prototypes so they are delayed
idbdoug
idbdoug is offline
Old 03-03-2018, 05:58 PM
  #611
vivo quevas's Avatar
What frequency do you set a R1 200 amp ESC for VTA?
vivo quevas is offline
Old 03-03-2018, 06:04 PM
  #612
You are over geared and over timed and at this point you need to have the rotor checked for strength. I run 3.07 gearing for 200' of full throttle. For carpet 3.6/3.7 is where I would start. 46 degrees of timing
Old 03-04-2018, 01:38 AM
  #613
Dan
Dan's Avatar
I've never heard of anyone running 3.6/3.7 gearing for F1 in 25.5, even on carpet...
But I will try 46-48 degrees and possibly ~2.8 on my next outing.
Dan is offline
Old 03-04-2018, 04:59 PM
  #614
Trader Rating: 55 (100%+)
Low. Most punch.
Antimullet is offline
Old 03-04-2018, 07:31 PM
  #615
idbdoug's Avatar
I run 88/27 64p for 3.26 with 55* degrees timing on endbell on black carpet and I just won our ROAR Regional race with this combo. I also have fan mounted.
idbdoug
texastc likes this.
idbdoug is offline
