Like Tree310Likes
R1 Wurks brushless motors
Old 12-14-2016, 12:26 PM
  #181
Johnny Wishbone's Avatar
Originally Posted by JAE
For the V7, what timing range and gearing is optimal for a associated b6 (2.60) for a medium to large clay track? Don't know much about these motors but picked one up
Are you using a motor checker or the timing marks on the motor? Which wind motor are you asking about? 17.5 or 13.5?
For stock I'll assume its 17.5. The timing should be 38-40* which will just be about the first notch on the timing mark. Gearing I can't say for certain, but think you will probably be 3-4 teeth less than what you normally run.
Johnny Wishbone is offline
Old 12-14-2016, 01:01 PM
  #182
JAE
Trader Rating: 30 (100%+)
Wow, so these motors take much less gearing than a Fantom? I'm running 17.5 stock buggy with a Fantom Type M and R at 69/29-31
JAE is offline
Old 12-14-2016, 01:19 PM
  #183
You can also try these links for tuning tips.
https://www.r1wurks.com.au/pages/r1-wurks-v11-tech-tips
https://www.r1wurks.com.au/pages/r1-wurks-tech-tips
Its all really selective on your part to what timing and gearing will work best. I'd start with the 38-40 timing and gear 2 less than you ran before and see what its like, then adjust from there. The tips applications are pretty good for all vehicles so don't be too concerned that is says TC opposed to what you are running. The timing I suggested is due to the heavier vehicle.
Old 12-15-2016, 07:46 AM
  #184
Be careful w/ end bell timing on the V7. Those motors have much more timing built into the can than newer versions. I haven't run mine in awhile, but I can check mine tonight on the motor analyzer and post back. Or someone else will probably post the info before that!
LAGuy is offline
Old 12-15-2016, 08:10 AM
  #185
JAE
I ran the v7 17.5 in my stock buggy for a few laps last night at 30 degrees timing at 69/28. Absolute rocket. Unbelievable. Was too fast actually for this really tight layout at a hi bite indoor track
JAE is offline
Old 12-15-2016, 08:49 PM
  #186
I checked mine and it's set to 18 end bell. Motor analyzer shows 51 overall And yes, R1's are fast!
LAGuy is offline
Old 12-16-2016, 11:11 AM
  #187
Hey Gary,
I'm looking at maybe a 21.5 for usgt; are the new V11 2017 high torque?; 12.5 rotors? I won't ask how they compare to motiv. I just don't want to have to buy a motor and then further tune with a ht rotor. Any suggestions is appreciated.
irvinew is offline
Old 12-16-2016, 01:35 PM
  #188
Trader Rating: 90 (100%+)
Originally Posted by irvinew
Hey Gary,
They come with the 12.5 ht rotor.
RBLove is offline
Old 12-26-2016, 09:48 AM
  #189
Hi guys. I plan on running a v15 17.5 in a 12th scale. Any info on what timing or amp draw to start at on the motor checker.
rezin is offline
Old 12-26-2016, 06:11 PM
  #190
I'd try 50* on can and a 93mm rollout as a starting point.
RBLove is offline
Old 12-28-2016, 05:28 AM
  #191
Thanks alot will try that!
rezin is offline
Old 12-29-2016, 06:39 PM
  #192
spammy's Avatar
So what will be a good starting point with the 17.5 v15 on gearing and what kind of rollout for a 12 scale in the 13.5 v15 this will put me in a good place
spammy is offline
Old 12-29-2016, 06:57 PM
  #193
DBM
How much does the 17.5 V15 weigh?
DBM is offline
Old 12-30-2016, 06:37 AM
  #194
For 13.5 start with a 84 rollout.
RBLove is offline
Old 12-30-2016, 06:47 AM
  #195
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I wanna say 167g if memory serves me..
hanulec is offline
