Like Tree310Likes
R1 Wurks brushless motors
Old 09-14-2016, 04:14 PM
  #151
Hey guys have a question. I have a 17.5 V11 and I run it in blinky. I have to have the end can timing at around 55 or so to get it to pull 6 amps under no load. Dosent that seem high for motor timing. Havent had a chance to run it so not sure what the temp would be. Anyone else running a 17.5 V11 in blinky and pulling 6 amps?
taz169 is offline
Old 09-14-2016, 04:33 PM
  #152
Trader Rating: 23 (100%+)
i've been told to run it around 55 so it seems about right
Zhangesh is offline
Old 09-19-2016, 10:10 PM
  #153
nova2015's Avatar
Hi, can anyone recommend a starting point for an R1 13.5 to run in blinky TC? Been running LRP and Tekin motors previously.
nova2015 is offline
Old 09-19-2016, 10:38 PM
  #154
Try here
https://www.r1wurks.com.au/pages/r1-wurks-tech-tips
Madmaxaus is offline
Old 09-20-2016, 07:54 AM
  #155
Sam Isaacs's Avatar
Trader Rating: 29 (100%+)
Hello. I would recommend a 4.5-4.6 FDR with 55 deg timing on the can for the V11, or 28-30 deg timing on can for the V7 motor. Check the temps as well, but it likely won't exceed 160F with these settings if you are running indoors.
Sam
Sam Isaacs is offline
Old 09-20-2016, 09:02 PM
  #156
nova2015's Avatar
Thank you, this will be outdoors, ambient temps 20-25 deg C.
nova2015 is offline
Old 09-21-2016, 03:59 AM
  #157
Sam Isaacs's Avatar
Those are pretty mild outdoor conditions. I think you will be fine with the settings as already posted.
Outdoors this year I ran a 4.59 gear ratio on my V11 with 54 degrees of timing on the can/motolyser, with an ambient temp of 90+F most days. If you have a fan, I would recommend using it.
Old 09-26-2016, 11:38 AM
  #158
Johnny Wishbone's Avatar
Default V11 17.5 issue
Anyone have a issue with keeping the phase C connection soldered to the motor?
I have a 17.5 V11 running 48* timing and geared at 3.88 and for some strange reason the C phase wire keeps unsoldering. First time was in warm up laps, so no real heat built up into the motor yet, and the second time was about 5 laps into a main. It comes unsoldered but it looks like it comes off as if the soldered never flowed to the terminal. Its almost like there is some kind of coating on the terminals that lets go.
Its always the C terminal. The speed control is a little warm, but I think this is due to the C phase coming off and limping the car to a safe place off the track.
I had one of the guys that solder for a living look at it and he couldn't see it being a cold solder joint.
I even cleaned all the terminals, and cut back the motor wires and re-tinned them with silver solder, and still had the same problem.
So anyone run into this, and did you find a fix. One of the guys suggested filing down the terminals in case the it some strange tinning put on them, might give that a try, but honestly can't say I've ever had this issue in many years of racing.
BTW, the motor is a beast when the wires stay on, lol.
Johnny Wishbone is offline
Old 09-26-2016, 02:29 PM
  #159
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
The timing plate is mostly likely the cause. It may be slightly bent and causing a short. Take off the timing plate and check it on a flat surface. Easy fix if you haven't overheated the solder on the stator.
Hope this helps.
Leonard.
DirtyDog3375 is offline
Old 09-26-2016, 10:05 PM
  #160
Hope this helps.
Leonard.
You nailed it. looks like my phase A was going to be a issue as well. Looks like when the timing screws are tightened the plate pulls out slightly. 3 screws would have eliminated the issue though. Thanks for the help.
Old 09-26-2016, 10:26 PM
  #161
Glad I could help and hope its all good mate.
Leonard.
Old 10-03-2016, 01:30 AM
  #162
Blui3's Avatar
Do Speed Passion Pro1.1 ESC and R1v11 (21.5t) motors like each other as I replace my old SP MMM motor with the R1v11 and now I get a delayed start off the line and sometimes it will stall for a second then take off again when doing laps. I see a fews post back about cogging. Its set at 5.9amps and 51* so would dropping the timing down stop the cogging.
Blui3 is offline
Old 10-21-2016, 10:51 AM
  #163
Trader Rating: 68 (100%+)
v15 on the website, any info for us little people?
todb is offline
Old 10-21-2016, 02:16 PM
  #164
jlfx car audio's Avatar
talking with someone with R1 at IIC i was told that its lighter , better timing balance , and cheaper ,
and 5 min later said it should be faster
jlfx car audio is offline
Old 10-21-2016, 02:21 PM
  #165
Hopefully all four.
todb is offline
