Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-23-2005, 02:26 AM   #121
Hi Malcom,
Have you managed to finalise any measurements for the MSX kit yet? A DCCF for that when it comes out would be awesome!
Andrew
Andrew Twigger is offline   Reply With Quote
Old 09-23-2005, 03:25 AM   #122
ooliganRC's Avatar
Send a message via MSN to ooliganRC
have a 3racing conversion for the TC4, just wondered if you where possibly doing one for that, looks very much like a yokomo sd one would fit, ill be at WLRC on sunday so if you have one I may get a DCCF.
cheers
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 10-04-2005, 12:27 PM   #123
asw7576's Avatar
What do you think about air scoop ? do you think air scoop is less effective than a small fan ? Fan draws power from battery. I'm using Orion V2 motor and sometimes the solder melted over 4 minutes of hard racing
Do you plug it to receiver batt or ch.3 ? Currently I'm using ch.3 for AMB transponder.
I'm thinking to use small fan ( or air scoop ) for Xray T1FK, but I don't want to lose volts and adding weight. However, I see why not to give it a try if the benefit is there.
Old 10-04-2005, 05:58 PM   #124
TheCoolCanFanMan's Avatar
Originally Posted by Gazza_D
Hi Malcolm,
hope you have some spare fans... need a new one after a racing incident broke one last weekend at Snett. Will try and catch up with you at WLRC on Sat if you are there.
Measured up for the Stinger yet???? Mine will be available at some point if you need to do a bit of measuring.
Gaz
Hi Gaz and lovely lady
Sorry mate just seen this, I know ive sorted you a fan now, but would love to get my hands on that stinger of yours please
TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-04-2005, 06:04 PM   #125
Originally Posted by Andrew Twigger
Hi Malcom,
Andrew
Hi Andrew
Yes we now have one for the MSX! Dave Spashet kindly let me take some measurements from his car, but will need to finalise and refine it before it will be availible on our site. But please do keep asking, but hope to have it finished and final fitting next week
TCCFM
Old 10-04-2005, 06:07 PM   #126
cheers
Hi,
We do produce one for the 3racing conversion TC4, and your nearly right, its the pro4 that fits perfectly and have them in stock
TCCFM
Old 10-04-2005, 06:11 PM   #127
Hi this is what is writen on our web site www.coolcanfan.com this should help you answeres to be met if not please dont hestate to ask away
Ok lets give you the low down on the Cool-Can-Fan kit, First of other makes of fans are of a ball bearing construction and WILL NOT work efficiently! as there make up will not allow the fan to work at its optimum because of the magnetic field within the motor. The magnets within the motor have a north and south pole divide, this is where the problem lies, as the magnets are trying to stall the fans at ALL times, I know this from experience as I had purchased a large number of the other fans myself and had to return them because of this situation. It has taken me to pattern up for each individual car a vast amount of time, so as to make sure that the fixings are correct and that there is NO drilling or filling needed as you locate the genuine carbon fibre bracket onto existing fixture points onto each individual model of car. Going back to the fan scenario, The fans we now use are far slimmer and far superior to the other cooling fans that are sold, the fans that come with the CCF are what's called a vapo make up, there are also sleeve bearing versions to, as you can see we have done our home work on this product and have sold over 700 kits to date since March 2005. They are sold all around the world including Australia :-) our fan's specifications are; 25x25x6mm (far slimmer than other makes of fan) 5 volt, variety, produce 2.2 cfm and run at a constant 11,000 rpm at a flat out running time of 1,000 hours. With regards to the clip on type of cooling fans that are available, the first thing that this product does, is to cover up the vent holes in your motor! which does not let the air circulate as the motor has been designed to do. The heat sink part of this item can move at any given time and sometimes come off in a crash. In some case even if you wanted to use a clip on fan, you couldn't, as some of the cars would not be able to be fitted to them, so this is another reason for the CCF all brackets are dedicated to each individual car, and fit precisely. There are many top team racers out there that use our CCF's Russell Williams TC4, Jason Butterfield Schumacher, Mark Burgess Schumacher, Stuart Rand Yokomo BD, Chris Kerswell Corally, Rob Baxter Pro4, and last, and not least even Dave Spashet has used our CCF and thinks it is a great product and many more to boot. So you see its not just a gimmick and a bit of bling, it does actually work, and for the money you save on brushes and not having the motor go soft on you its WORTH every penny :-)
TCCFM
Old 10-04-2005, 06:24 PM   #128
seamus0g's Avatar
How about the Factory Team TC4?
seamus0g is offline   Reply With Quote
Old 10-04-2005, 07:57 PM   #129
TryHard's Avatar
Originally Posted by Trakside Trucke
Hi Andrew
TCCFM
Malc, excellent news
My MSX is due to arrive this week.... I'll be needing one of thoose DCCF asap
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-04-2005, 08:02 PM   #130
TryHard's Avatar
TCCFM
Hey Malc, wheres my name in that lot
Still, soooooo true, the CCF's really DO work!
I've run mine on my 415 for the best part of 6months or so, and I've never ever had a motor go soft on me yet... plus it makes the motor cool to work on after marshalling.
Ed
Old 10-04-2005, 08:10 PM   #131
Matt Howard's Avatar
So how much does one of these run? for the BD specifically. The website doesn't give any prices
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-04-2005, 08:19 PM   #132
HarshGuy's Avatar
Email them to get US pricing.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 10-04-2005, 08:22 PM   #133
stop stalking me don't you have gearchart.com to go fix or something
RCTech #361
Old 10-04-2005, 08:41 PM   #134
HarshGuy's Avatar
No I'm pretty much done with that, now all I got left to do is stalk
Old 10-04-2005, 08:44 PM   #135
you need a hobby
RCTech #361
CRT.5 talk! sidewayz Singapore R/C Racers 149 10-29-2008 11:49 PM
Anyone what talk about sports? losi09 Chat Lounge 19 03-01-2007 10:13 PM
B4....the one they talk about.... 2PAC R/C Items: For Sale/Trade 11 05-26-2004 01:35 PM
motor talk murfy Australian Racing 40 01-30-2004 12:18 AM
1/12 talk ultra_low_life Malaysian R/C Racers 90 11-22-2003 08:22 AM
