Cool Can Fan Talk
#646
#648
#650
#652
Hey mate,Still doing them for the JRXS,Also how much to get one send to New Zealand?
#653
Hi Malc does the Cyclone mount go onto the rear bulkhead ??? as I haven't seen a pic of the cyclone Fans installed
What size are the fans ie 5 volt or 7.2 could I connect it direct to the speedo or does it have to go to the reciver as I have not got a spare slot in the reciver
I need one I fried 3 motors last weekend !! Do they cool Brushless motors with no holes in them or do they work best with makes of motor with cooling holes in the cans ???
Last Question are they a stock item ??????
#654
I think there is a pic of the CCF on a WCE somewhere on this thread
What size are the fans ie 5 volt or 7.2 could I connect it direct to the speedo or does it have to go to the receiver as I have not got a spare slot in the receiver
The fans are 5, volts but work perfectly ok with 7.2 and 7.4 cells. as they have done with this product for the last 3 years
This is how I personally connect the CCF, as the fans will still run when the ESC is switched off, and therefore will be cooling the motor down whilst your marshaling.
I have one on my WCE, and it works as well on brushless as it does with brushed motors, I use the Novak SS and does not have any vent holes in it, but helps keep the heat down to upto 50%. I will also be putting one on my TC Clone, as it has the same mountings
Hope this helps you
Yes they are in stock
Cheers Malc THE
CAN
MAN
Hope this helps you
Cheers Malc THE
#655
#657
I have the WCE and the TC and both have CCF's on, in fact my TC has a CCF+ which as you can see by the pic hangs off of the original CCF. The fans are 25mmx6mm The cost of the CCF is £29.99 and the CCF+ is £14.99 + £6.50 postage
Cheers Malc
#659
Hi,
Do you have any pics of the TC5 CCF setup? i looked on the site but no pic and i wasnt able to order from the CCF site either.
Sean
Sean
#660
have a look on page 21, #619 there is a nice pic there
Cheers Malc
If you want one, just pm me with your email addy, and I will send you a paypal invoice
