Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-19-2005, 08:03 AM   #1411
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hey Curtis,
may i know if i using 7x1 UL arm in orion V2 can will it be possible to gear 7.8 until 8.1 ratio for the FEMCA track? will it burn easily?? because on the track that few people using 7x1 cobalt motor and they gear 7.6. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 11-19-2005, 01:07 PM   #1412
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
Originally Posted by Guo Chean
Hey Curtis,
Hi Guo,
For Kota Raja Speedway I would say start with this on your 7x1 V2 UL motor:
9 Degrees timing
Sprint Edge Brushes
MR - Med Hard Springs (one step below the stiffest)
Geared at a 8.5 FRD
If more top-end is needed gear up, if more bottom-end RIP is needed turn up the timing to 12-14 degrees (but only if runtime is not an issue, otherwise you will probably dump).... Hope this helps, look forward to meeting you next month...
Curtis,
Curtis Schlaht is offline   Reply With Quote
Old 11-20-2005, 11:42 AM   #1413
racer-oZ's Avatar
R/C Tech Charter Subscriber
curtis, you've got mail!
racer-oZ is offline   Reply With Quote
Old 11-20-2005, 12:50 PM   #1414
Default Brush Alignment?
if the brushes are not aligned properly will there be a black mark on the trailing edge of the brush?
SPC Racer is offline   Reply With Quote
Old 11-20-2005, 12:59 PM   #1415
mini-dub's Avatar
Trader Rating: 16 (100%+)
My brushes get that also, on the XXX ones. I think its caused by the little bit of arcing from not being perfectly seated. I haven't noticed it to cause any problems though. I break my motors in with XXX brushes at .7 volts for 4 minutes then 1.2 volt for 30 seconds. When I rebuild my motors each run I use a fiberglass comm brushes and clean the whole brush.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 11-20-2005, 01:12 PM   #1416
SPC: It's just caused by arching, low turn high RPM motors with stiffs springs and high timing will always get a build up of carbon on the trailing edge of the brush, this is considered to be the norm on square brush mod motors..... IF the brushes were out of alignment you can visually see this in the way the face of the brush has worn (viewed from the top of bottom of the brush)....
Curt,
Old 11-20-2005, 03:31 PM   #1417
what about stock and 19t motors?
Old 11-20-2005, 08:01 PM   #1418
The same goes for stock and 19 turn motors as well.... The increased overlap provided by a laydown brush increases arching, so it is not uncommon to see a slight amount of carbon build up on the trailing edge of the brush face.... We've been narrowing the brush slightly by removing .015" off the trailing edge of the brush, this in turn reduces arching and heat buildup while at the same time providing slightly more torque....
Curt,
Old 11-22-2005, 02:54 PM   #1419
STLNLST's Avatar
Trader Rating: 21 (100%+)
TTT
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-22-2005, 06:19 PM   #1420
tc3 racer sc's Avatar
Curt,
hey boss i been looking for my order i guess u forgot hve a good time in clevland
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 11-24-2005, 03:10 PM   #1421
Alex_kipper's Avatar
Hey curtis i tryed to send you a PM and it says that you no longer want mesages...
and BTW: Where is my motors...its been 2 weeks since you sent it!!!
Alex_kipper is offline   Reply With Quote
Old 11-24-2005, 03:22 PM   #1422
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Curtis is in Ohio for the race. He may not be able to get his messages.
EA Motorsports
picco007 is offline   Reply With Quote
Old 11-24-2005, 03:55 PM   #1423
Company Representative
Trader Rating: 15 (100%+)
it might be stuck in customs.
my last DC order was stuck for a month...lol
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 11-25-2005, 04:50 AM   #1424
highwayman's Avatar
Curtis Schlaht :
for the Kota Raja Speedway, would you recommend a single or double wind?
for a Ti3 8x1, should i go to around 8.1 to 8.2 FDR?
thanks -jason
highwayman is offline   Reply With Quote
Old 11-25-2005, 08:38 AM   #1425
Default Welcome to Malaysia
Hi Curtis,
Welcome to MALAYSIA for our very first FEMCA ISTC CHAMPS.
regards
aaron
Hi Highwayman,
What car are you running.
cheers
aaronkhoo is offline   Reply With Quote
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
