Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-28-2005, 10:42 AM   #1081
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
Markg: I'll email you...
Alex: PM sent.....
highwayman: So how exactly did the brush wear out in 5 runs? Are you saying the brush wore so much it during these 5 runs that the back of the spring wouldn't make contact with the brush anymore? If that's true I, WOW , never heard (or seen) a XXX brush wear out in just 5 runs.....
Curtis Schlaht is offline   Reply With Quote
Old 10-28-2005, 08:26 PM   #1082
highwayman's Avatar
no, it wasn't that bad, the brushes were probably 60% to70% of the original length after 5 runs. i was thinkin maybe the trinity purples were too strong ???
highwayman is offline   Reply With Quote
Old 10-28-2005, 08:36 PM   #1083
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I've ran purples with extra tension on them on an 8x1 with hardly any signs of wear.... the springs shouldnt be doing it...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 10-28-2005, 09:33 PM   #1084
Brian: He was using them on a KR not at Ti3....
Jason: Purple springs should be fine, that's what I would have recommended to start off with.... What exactly was your problem? The more details the better
Curtis,
Old 10-28-2005, 10:00 PM   #1085
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I have suffered the same problem with my Ti3 actually. Not sure exactly of the problem and haven't really tried to sort it out, just threw in a DC V2 and I was going again.
What happened to mine was that it has got great power for the first 5-6 runs, everything runs smoothly and I think its a better motor then my V2s. Then, I've had this happen with 2 sets of XXX brushes now, the motor lost power throughout the run. It dramatically lost performance and was running as if it was a Stock motor by the end of it. Not sure exactly of the problem, but when I find the problem (now that I have time away from uni exams) I'll let you guys know.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 10-28-2005, 10:50 PM   #1086
A wile back we had gotten in a batch of springs that wasn't bent properly, at the time we didn't notice the defect. What had happened was the hook (U-Shaped bend) at the end of the spring was flattened out a bit (making the spring a tad bit longer than it should have been). This in turn caused the spring to hit the inside of the brush hood as the brush wore, reliving tension on the brush itself, causing the motor to slow and act like a hung brush.
A simple squeeze with a pair of needle nose pliers to rebind the end of the spring is a quick and easy fix.... Since we've noticed this defect we switched spring manufactures, our Ti3 modified motors now come with heavy black Reedy springs.... Hope this help, sorry for the inconvenience...
Curtis
Old 10-29-2005, 12:58 AM   #1087
Trader Rating: 22 (100%+)
Alex: PM sent.....
Highwayman
I have had the same thing happen to a KR motor I have a feeling it is a gearing issue and the fact that these brushes dont tend to chew up the comm when not geared right.
The brushes tend to not damage the comm as much if geared incorrect but get excessive wear when hot, try running the same gearing with your standard type brush and see what happens. You will probebly have no comm left! I have found the larger comm low wind mods very hard to gear just right and very flat torque band (ie Ti worlds,KRs ) better a Ti 3.
bjspinner is offline   Reply With Quote
Old 10-31-2005, 03:13 PM   #1088
mini-dub's Avatar
Trader Rating: 16 (100%+)
Hey Curtis, thanks for the canned power you sent me , those motors were awesome. The 7x1 5mm at 18 degrees and the 8x1 4mm at 18 degrees were stupid fast, for the 8x1 5mm I ran 22 degrees. Since I was running my stock and 19t packs which didnt have the greatest runtime from the IIC and they had been dead shorted, I was dumping the last lap and a half in qualifying with the 7x1. That was just because the traction was so high, when it was lower I could run 6 minutes on the 7x1 . So I switched to the 8x1 5mm and had no problems at all with runtime. I finished 2nd overall in mod with Much More's Keith Yu 1st and Peter Robinson 3rd. The only power I was lacking was because of my stock 3700's. Everyone running DC power at the Slugfest had tons of power.
Weylin
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-31-2005, 04:27 PM   #1089
Korey Harbke's Avatar
Mine were stuid fast as well curtis. I ran pretty much the same setups as Weylin, I just had alot of bad luck on my part. I did manage to put my VFS-1 into thermal overload in my best mod run.... lol. It was a fun weekend, learned alot as far as drivign and setup. tuned a few DC quad mag 19T for people and they had loads of rip as well.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-01-2005, 01:24 PM   #1090
Weylin
Congrats on your 2nd place, that's not to shabby ..... Keep up the good work and thanks for the support.
Curtis,
Old 11-01-2005, 01:28 PM   #1091
-Korey
Thermal shutdown , that's when you know you're going fast LOL.... Appreciate the help with the quad mags, what were you using for brushes and springs??? Just curious....
Curtis,
Old 11-01-2005, 01:39 PM   #1092
Hi Curtis
The Outlaw 19T U/L is a stupid fast motor very impressed by its speed gives alot of mods something to worry about.
Have you been busy I am waiting for my order #169 can you please let me know the status of this order. Thanks.
Old 11-01-2005, 02:06 PM   #1093
Originally Posted by bjspinner
Hi Curtis
Hi Bruce,
Glad you liked the motor, so far we've had nothing but good comments about the Outlaw 19 motors/arms ..... Your motors are ready to shipped, just waiting on more SXT to show up (hopefully by Thursday well get more SXT 1.0 & 2.0 in), I accidentally inputted the wrong inventory amount into our e-shop so we're over-sold by a few cans at the moment, Dohhhh , sorry about that bud....
Curtis,
Old 11-01-2005, 04:47 PM   #1094
F brushes with a cavity drilled in the center. I think I used one of those Racers edge #54 finger drill bits..... it's all I had at the moment. Red springs seemed to work good. I tried purples and purple/red for myself and it was too heavy, and red/green seemed too light.
-Korey
Curtis,
Old 11-01-2005, 05:40 PM   #1095
-Korey
Thanks Korey....
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
